521 - 540 of 684 Posts
[quote author=adumbrille link=topic=104068.msg4029208#msg4029208 date=1305925420]
A ratchet with like a foot to a foot and a half of extensions is what I did.
I can get the length NP but the angle that its hitting @ wont allow the socket to catch.
Ok I just tried it again. Took about 2 minutes to get it to catch for me.
Use a 6 inch extension:
Take the extension off the ratchet so you can feel for it better. When I had it catch it was on the left edge of the hole and angled slightly up.
Then attach the ratchet after it catches and you'll be in business. Putting it back on is the fun part :p
Finally managed to get it caught. I was looking at the wrong bolt peeping through the first port by the throttle body. I tightend it back up because I'm short on time and I'm going to read through again and see where I need to look to find the right bolt so I don't lose it when it comes out. Sure enough though upper left of the hole
To put the bolt back on I used some paper tape, like painter's tape, and taped the bolt to the extension, inserst the extension, then attached it to the ratchet. After tightening it, just break the tape.
Well the ecu has a rev limiter at 6800 rpm...so I don't know how you got to over 7800...either your tachometer has lost calibration or your ecu's been tinkered with. Even if it is actually 7800, the engine can run to 8200 on stock internals...supposedly. If anyone else has any ideas, chime in please.
Yeah you can there's Hypertech http://www.hypertech-inc.com/Default.aspx and dp tune http://www.dptune.com/ both which can raise the redline. Since your car is an 05 and Hypertech doesn't do 04 & 05 it would be the dp tune. Obviously he wasn't b-s ing LoL. You should be fine, like I said revving to 8200 is ok before things fuck up. Interesting that it went up though. Most likely, since your rev limiter was raised, your top speed was as well. Normally our cars go to 118..you should try to go to 140 and see if it lets you :p
