541 - 560 of 1,132 Posts
I noticed yesterday that the the unit leaves a small gap from the bottom between the unit and the ac controls. And i can see plastic clips from the ac controls from the gap. I tried to see if there is a way to stick these clips inside the unit so there isnt a gap but i couldnt . Has anyone else noticed that or is there a workaround?
Yes, it's possible. If you have TAPE/MD button on the factory head unit, you HAVE TO BUY A NEWER LCD and make some wiring modification. Here is the step-by-step instructions: http://www.mazda3forums.com/showthread.php?t=387058
Thanks for seanlin08!
The trip computer will NOT WORK! But it's only the canbus decoder what can't handle it. I try to buy an MZ-SS-02 what packed with D/G/GM5151. I still not understand why Eonon not send it with the GA5151.
BUT all these infos there in this thread! Please read it!!!
Ok, thanks peti007.
If I understood right, I will install 06-09 lcd and hope it works correctly. Then I will be able to install ga5151 head unit and all should work well?
Do I have to order that can bus decoder also or does it come with eonon?
What is actually that can bus?
Discussion starter · #543 ·
The trip computer info that used to show from the left side of the lcs that it shows the clock .I am talking about the LCD display not the head unit. Like fuel consumption and every fuel related info .
I read from earlier posts that the can decoder from gm5151 works with ga5151 without loosing trip computer info. If is that the case have you ever tried to use the gm 5151 decoder with ga5151 unit ? Its a shame gm series models of eonon everything works and on the newer version trip computer doesnt work.
Also the radio reception like other members noticed isnt as good as the oem unit. Is there any way to improve that?
Needless to say anything :angry:
Hi mazdakaps & peti007, Yes, GA5151 supports the trip computer, but it only can display part info. Just as i said the CANBUS BOX of GA5151 now can only support the unit to display the time ( Clock) and navi info on the LCD display at present, it cannot display the fuel consumption info. Since it has different project of GM5151, so your kind understanding will be very appreciated.
So now whether your unit can display the clock and the navi info on the LCD display or not? If not, please PM me your email address and order No. So that i can help you better. Thanks.
Discussion starter · #544 ·
Another question. Tried to connect my obdII bluetooth device with ga5151 . It sees the device in settings bluetooth try to connect but nothing happens. I believe it should ask me for a code to connect to the device but nothin happens. Any tips about that?
Thanks
Hi mazdakaps, the code is 0000, have you filled in? And please try another phone for checking. If it is still the same, please PM me your email address and order No. Thanks.
Dear Melvin,
You say GA5151 supports trip computer. Do you know what trip computer mean? http://en.wikipedia.org/wiki/Trip_computer
So the fuel consumption info IS what trip computer mean!!! So please don't say it supports it.
What I can't understand and asked before but you didn't answer:
Why don't you send the MZD-SS-02 canbus box with GA5151 what you send with D/G/GM5151 and D5151Z. You give it to ga!nusha to test it and he said it works!
http://www.mazda3forums.com/showpost.php?p=9688433&postcount=194
http://www.mazda3forums.com/showpost.php?p=9689433&postcount=198
Swance5021 tested it too and worked:
I don't uderstand what your technicians work on? Your buyers give you the solution! It's internet's miracle few people far from each other can work together.
I succesfully made the lcd conversion yesterday thanks to seanli08!!!. For the records, my car is a European (Spanish) 2004 mazda3 and I used a 08' display from a junkyard . It worked exactly as expected here: it shows amb and climate temp and time. I will be searching the post about how to set the clock.
Then, just to couple of things pending:
1. Make the Bluetooth works in all situations (elm32 and file transfer) following mazdakps steps (thanks again!) And
2. After the initial installation the little yellow led icon light for the headlights is allways on. Even when I take the carkey out and lock the car. I do no think I have read in the post anyone with this problem.
Discussion starter · #548 · (Edited)
Dear Melvin,
Hi peti007, thanks for your suggestion and detailed explanation. But our unit can only display clock and navi info at present. Our factory is working on this function.
And i found that you bought this unit from another seller, could you please ask your seller for help directly? I think they will give you best solution. Thanks.
Discussion starter · #549 ·
[Members Always Get More] :peace:
Hi guys, great news to tell you that if you register an account or already have one, and order products from our website during Apr. 24 - May.10, then you can enjoy 2 FREE Cool Gifts!
Including A0411 three USB Ports Car Charger & A0414 Creative Hook! Values 30USD!
Our Way of Saying Thank You ;)
Please know more details here:
http://www.eonon.com/member_2015.aspx
I've installed the device and I am loving it. I have my Ipod touch 4 connected directly through the provided ipod connection and I ran the cord out through the ashtray.
I noticed the stock media player for iPod and USB devices does not display album art. Can anyone recommend a media player that would detect the iPod or USB media with a nicer interface? Something on the play store maybe?
Any other app recommendations that improve the experience?
I bought my unit from Eonon so I guess I will say it...
Dear Melvin,
http://www.mazda3forums.com/showpost...&postcount=194
http://www.mazda3forums.com/showpost...&postcount=198
Let me Enjoy
I have noticed this too and plan to take the nubs off of the Climate Controls with an exacto knife or razor blade. I am just waiting on some warmer weather to run my cables exactly where I want them and I also want to try to take the faceplate off of the radio to see what options I have for color matching.
I am sorry to post so many post at a time BUT I had a weird issues today. I got into the car and after boot up I noticed I only had sound coming from the Front Passenger speaker. It was really odd. I played with the Amp to make sure. It was about 36 Degrees Fahrenheit so it wasn't that cold. When I went out for lunch it was about 55 Degrees and acted like it was going to do it again but then all speakers kicked on. I am running a stock Non-bose system. No Amps or aftermarket Speakers installed. I have a 2008 Mazda 3 Sedan.
Dear Melvin,
Let me Enjoy
:nice:
Dont do this
Everything was explained few pages ago
you need to transfer stock clips from your original radio
EONON fits flush with original stock white clips
Dont do this
The original stock clips are transfered but the climate controls below have two plastic clips that hitting on the bottom side of the unit and this leaves a gap
Yes my unit is sitting flush in the dash but not flush with the climate controls like the stock radio. I will take pictures this weekend to show everyone what I mean and hopefully a finished result.
Discussion starter · #560 · (Edited)
I dont understand if i buy eonon unit from another seller i cant have eonon support? What kind of logic is that?
Hi mazdakaps, we make a deal that the another seller should be responsible for their customer. So please just contact them directly if you bought from them. They will give you a solutions. If they fail to do it, just give me his store name, we can help to negotiate with that seller. Your understand will be highly appreciated! Thanks.
So we will greatly recommend you to buy from our official site directly: http://www.eonon.com/, so that we can provide best service. :)
