Which PSI to set tires?
5.4K views 10 replies 11 participants last post by  the415
#1 ·
Do u guys set the tire psi to what the tire manufacturer recommends or to what the mazda3 recommends?
#2 ·
By law, the correct tire pressure should be on inside of your door where the door meets the body and also somewhere in your owners manual. Do a search next time because whatever you need to know is USUALLY already posted somewhere else...and it should be around 45PSI.
#8 ·
45 = dangerous and you'll have chicken strips.
32 is the norm. Try that and add if you need by feeling how it handles.
I run 35 front and rear on 225/40/18
#9 ·
i'm not sure either . i have 17'' , they are 7'' wide , tires are stock RSA's. the tire place set it at ~ 36 psi, but i'm not sure if it's right.
#10 ·
[quote author=balding geezer link=topic=116679.msg2441176#msg2441176 date=1215284707]
As long as you respect the minimum and maximum recommended pressures I don't don't think you'll have a problem. Mazda recommends 34 psi front and rear for my 15s. Toyo recommends 44 psi. I run 'em at 44. The car is a bit more pointy that way and I figure the extra 10 psi may help fuel economy.
Just to note: The tire inflation on the tire itself is the manufacturer's MAXIMUM tire pressure. It has nothing to do with what they recommend. When push comes to shove, they will tell you to follow the vehicle manufacturer's recommended pressure.
#11 ·
what some of you fail to realize is that when you get different size tires, you can't always go with what's on the door. in that case, go by the tire manufacturer's recommended settings. i run 36-38psi in my 225/40/18's.
