Sway bar end links advice
2.5K views 7 replies 4 participants last post by  nerv81
#1 ·
Ok, so I've had the Cobb rear sway bar on my car since approx February on the stiffer setting. I've had no probs since installed untill last week. When I go over bumps I was hearing a knocking sound kinda like a blown out shock. I forgot I had the sway bar so I went to the dealer and they said it was a bar end link but wouldn't warranty it cause of the sway bar. (I know, i'm a dumbass for not taking it out :slap: )
So I decided to take out the sway bar and take my car to another dealer this week. Well I took my car for a test drive after putting the stock on back in and now the sound is gone. Even when I took it out, I checked the end links and they seemed ok. So I have 2 questions...
1) Should I still take the car to the dealer since it's not making noise for a second appointment? And will they do anything since there's no noise anymore?
2) How can I tell if my end links are bad?
Eventually I'm going to upgrade the links but funds are tight right now so I gotta wait.
#3 ·
Bigger sway bars make nasty noises when the endlink bolts get even slightly loose... I bet one just started coming loose, but you didn't notice when taking it off. If you make sure the surface of the bar is clean, and tighten down the endlinks to the bar really well, the sound should go away.
#4 ·
Well the next few days are going to be freezing so I won't get to it till this weekend. I was thinking about using the softer setting on the Cobb since the holes line up in the same spot as the OEM. Right now the car is rattle free so it definately seems like it was just the bolt. How do I know for sure if the end link is good through. I've been reading the forums and my best friend Google but I can't find a definately way to test. I also found that the original Mazda ones are better than the aftermarket. Is that true?
And no, i'm not using a torque wrench because of the allen key. Can't get the socket over it. I'm using a ratcheting wrench and going pretty tight with some thread lock. It was a biiaaaatch taking the bolts off because of the thread lock so I didn't think the bolts were the problem but apparently I was wrong.
#5 ·
Mazda's testing procedure is to rotate the bolt portion 10 times and then side to side 10 times. Then check the rotational torque. If it's outside spec, replace it. I would also look for binding when you are spining the bolt portion, or moving it side to side.
#7 ·
I run a whiteline rear sway bar on my Maz 3 SP 23 (I'm In Aust) and have a similar noise. It turns out that the sway bar was made with a larger hole in the sway bar than the bolt used to attach it.
This means that no matter how tight it is done up the bar still moves a bit when it moves. Problem is I do not think there is any end link that has the correct diamiter. Just for refference the end link is a 10mm bolt the sway bar is a 12 mm hole. (one whole bolt size larger)
#8 ·
So I went to a different dealer last week to fix the window ticking issue and had them check the end links (I have the stock sway bar on it now) and they said the links are fine and the bolts are known to come loose so they re-torqued them just to make sure. So it looks like when I put the Cobb back on, i'm going to use thread lock again, but I'll also put on a 2nd nut for extra protection.
