settings for Koni yellows with stock springs
1 reading
2.9K views 3 replies 3 participants last post by  jheer
#1 ·
Folks,
Finally installed my Koni yellows on my Speed3 with the stock springs. What is generally the recommended settings for the Konis? I have heard for daily driving and occasional autocross that I should set them mid-way. Any other opinions?
#2 ·
The same settings on two shocks will not be the same unless you bought a matched pair. It will be a trial and error, but you should be able to get them dialed in. Once they are where you like them for autocross, I suggest you never touch them again. The dampening becomes crazy at the far ends of the dial, so be careful if you are near one of the extremes.
#3 ·
i'd say for stock springs rebound setting around 1/2 way to firm would be fine as a starting point.
#4 ·
[quote author=jheer link=topic=169797.msg3596344#msg3596344 date=1270156848]
Folks,
Just an update:
I installed the fronts and backs at about 3/4 toward the firmest end. For daily driving on Cleveland roads, this was too firm. I just dialed the fronts back about half a turn each, and the ride is much more liveable for daily driving. I will increase by the 1/2 turn for any autocrossing. Because the backs are not adjustable without taking them off the car, I will just have to live with them being a bit too firm for daily driving.
