How-To: Speed3 Trans Swap Into MZ3 - Updated 9/14/10
1 reading
77K views 102 replies 23 participants last post by  heimsothe
#1 ·
Special Thanks To Aminzer and Cain who provided 99% of this information to me.
This Information Pertains to Swapping from an '05 with a 5 speed G35M-R, to the speed3's A26M-R.
Your Parts May Vary.
Non-ABS cars and Automatics will not have a speedo if you do this swap. This is due to the fact that non-abs and automatic cars use a speed sensor on the transmission. Cars with ABS use the ABS sensors to drive the speedo.
This parts list pertains to my '05 MZ3S with the 5 Speed Manual, your parts may vary.
Transmission:
Stock - G35m-R
MS3 - A26m-R
Obviously Need The Transmission.
Stock Used Price - $400-$1000 depending on mileage
MS3 Used Price - $1000-1500 depending on mileage
I Bought One For $1281. From An '07 MS3, 40k Miles, 100 Day Parts Warranty.
Transmission Sensors:
Stock - Neutral + Reverse Switch (Optional Speed Sensor)
MS3 - Neutral + Reverse Switch
Sensors Are Compatible For All Manuals With ABS. Speedo Uses ABS Sensors.
If you have a manual car with ABS your speedo will still work, if not then you are SOL.
Axle Diameter As Measured At The Hubs:
Stock - 1.083in (measured on top of splines)
Stock - 1.063 (measured between the splines)
MS3 - 1.125in (measured on top of splines)
MS3 - 1.083in (measured between the splines)
Hub Sizes Are Different. Need To Replace Hubs.
Stock Used Price - $50-125 ea.
MS3 Used Price - $40-125 ea.
Axle Diameter As Measured At The Differential:
Stock - (measured at top of splines)
Stock - (measured between the splines)
MS3 - (measured at top of splines)
MS3 - (measured between the splines)
Axle Sizes Are Different. Need To Replace Axles.
Stock Used Price - $100-200 for a set
MS3 Used Price - $300-400 for a set
Input Shaft Diameter:
Stock - 22 teeth
MS3 - ? teeth
Input Shaft Sizes Are Different. Need to Replace Clutch.
Flywheel Depth:
Stock - (depth)
Stock - (diameter)
MS3 - (depth)
MS3 - (diameter)
Flywheels Are Different Depths. MS3 Flywheel Is Dual Mass And Much Thicker. Need To Replace Flywheel.
Slave Cylinder Configuration:
Stock -
MS3 -
Slave Cylinders Are Compatible.
Slave Cylinders Have Different Piston Diameters. This Greatly Changes Pedal Effort. MS3 Slave Strongly Recommended.
Shifter Configuration:
Stock -
MS3 -
Shifters And Cables Are Different. Need To Replace Shift Assembly.
Gear Ratios:
Mazda 3:
1 3.307
2 1.842
3 1.310
4 0.970
5 0.755
R 3.166
Final 4.105
Mazdaspeed 3:
1 3.538
2 2.238
3 1.535
4 1.171
5 1.085
6 0.853
R 3.831
Final
1-4 3.941
5-6 3.350
http://img40.imageshack.us/gal.php?g=img0407ha.jpg
#2 ·
Re: How-To: Speed3 Trans Swap Into MZ3
Pics Of All Parts Needed For 6-Speed Swap
Transmission
Axle Measurements
Input Shaft Measurements
Pressure Plate Measurement
Clutch Measurement
Flywheel Measurement
Shifter
Shifter Linkage Measurement
Hubs
Rear Motor Mount Bracket
Axle Seals
Rear Main Seal
#3 ·
Install Procedure
This procedure is for an '05 MTX. This is how I chose to do it, there are different ways, but having pulled the trans before, this is what I think is the fastest and easiest to do, WITHOUT A LIFT.
1) Raise front of car on jack stands as high as you can
2) Remove the front wheels
3) Use an impact to remove the axle nut/bolt (NOTE: if you do not have an impact, have someone hold the brakes while you loosen the nut/bolt)
4) Remove the brake caliper and caliper bracket
5) Remove the bolt which holds the lower ball joint in place
6) Remove the 3 bolts which holds the lower control arms on (NOTE: You will need a very long breaker bar for this)
7) Remove the LCAs and set it aside
8) Remove the 3 bolts which mount the strut hat to the tower
9) Remove the entire strut assembly from the car
10) Remove the bolt which holds the steering knuckle to the strut
11) Using a maul hammer, hammer on the steering knuckle to separate it from the strut
12) Using a maul hammer, hammer the new steering knuckle onto the strut (NOTE: be sure you have the correct side knuckle)
13) Insert and tighten the bolt that holds the steering knuckle to the strut
14) Set the struts aside
15) Remove all plastic covers in engine compartment
16) Disconnect the battery
17) Remove the battery
18) Disconnect the ECU
19) Remove the 3 bolts which hold the battery tray in place
20) Remove the battery tray and set it aside
21) Remove your intake
22) Remove the 4 bolts which hold the header heat shield in place
23) Slide the header heat shield back towards the firewall (NOTE: you do not need to full remove this, just slide it back for clearance)
24) remove the 4 nuts which hold the drivers side mount bracket in place
25) Remove the 2 nuts which hold the battery box bracket in place
26) Remove the battery box bracket and set it aside
27) Drain the transmission of oil
28) Remove the 3 bolts which hold the passenger side jack shaft in place
29) Remove the passenger side axle assembly (NOTE: I left the drivers side axle in until the trans was out. it is hard to get out due to the snap ring)
30) Remove the 3 bolts which attach the rear motor mount bracket
31) Remove the rear motor mount
32) Place a floor jack with a block of wood under the engine
33) Pump the jack until the wood contacts the oil pan, then give it 1-2 more pumps until it is supporting the engines weight (NOTE: do not lift the engine too much)
34) Loosen the bolts around the perimeter of the transmission bell housing (NOTE: do not remove the bolts all the way yet)
35) Place a transmission jack under the transmission and pump it until it is supporting the transmission
36) Remove the bolt which attaches the transmission to the drivers side mount (NOTE: you are going to need that breaker bar again)
37) Remove the drivers side mount
38) Remove the shifter cables from the transmission
39) Unplug the 3 connectors on the transmission
40) Remove the 2 bolts that hold the slave cylinder on
41) Remove all the bolts around the perimeter of the transmission bell housing
42) Separate the transmission from the engine
43) Lower the transmission out of the engine bay and then slide it from under the car
44) Remove the 6 bolts that hold the pressure plate on (NOTE: you will need an impact for this)
45) Remove the clutch and pressure plate
46) Remove the 6 bolts that hold the flywheel on (NOTE: you will need an impact for this)
47) Rock the flywheel back and forth to remove it
48) Remove the 6 bolts that hold the rear main seal on
49) Carefully pry off the rear main seal
50) Put a bead of RTV along the where the block meets the pan and install the new rear main seal (NOTE: read the directions on rear main seal)
51) Use a seal puller to remove the pilot bearing (NOTE: This is difficult to do as it does not want to come out, be very careful when doing this as you will mangle it)
52) Insert the new pilot bearing and use a socket to tap it in place
53) Remove the release bearing from the MS3 transmission
54) Install the new release bearing on the MS3 transmission
55) Install the MS3 flywheel
56) Insert and tighten the 6 flywheel bolts to spec
57) Place the pressure plate and clutch against the flywheel and insert the alignment tool
58) Insert and tighten the 6 pressure plate bolts
59) Remove the alignment tool
60) Remove the interior kick panels around the tunnel
61) Remove the 2 nuts that hold the shifter linkage to the firewall
62) Remove the 4 bolts that hold the shifter base to the floor
63) Remove the shifter base
64) Slide the shifter linkage into the interior of the car and remove it
65) Slide the new shifter linkage through the hole in the firewall and into the engine bay
66) Install and tighten the 2 nuts that hold the linkage to the firewall
67) Install the 4 bolts that hold the shifter base to the floor
68) Apply some anti-seize to the end of the MS3 transmission input shaft (NOTE: this is to make it easier to slide into the clutch disc)
69) Place the transmission on the trans jack and slide it under the car
70) Lower the engine slightly so it is at a bit of an angle
71) Jack the transmission into place (NOTE: you will need to make sure the trans is in the correct orientation in order to get it to fit in)
72) Slide the input shaft into the clutch and make sure everything is lined up
73) Push the transmission into the engine
74) Insert the bolts that attach the transmission bell hosuing to the engine and finger tighten them
75) Gradually tighten the bolts until the gap between the engine and transmission closes
76) Jack the engine and transmission up until they are level again
77) Tighten down all the bell housing bolts to spec
78) Place the drivers side mount in place
79) Jack the transmission up until it is flush witht he mount
80) Insert and tighten the drivers side mount bolt
81) Lower the transmission jack and remove the jack from under the engine
82) Remove the axle seals with a seal puller
83) Install the new axle seals by gently hammering them in with a socket
84) Install the Axles and fill the transmission with oil
85) Insert and tighten the 3 jack shaft mounting bolts
86) Install and tighten the rear motor mount
87) Insert and tighten the 3 rear motor mount bracket bolts
88) Insert and tighten the 2 bolts that hold the shifter linkage bracket to the transmission
89) Insert and tighten the 2 bolts that hold the slave cylinder to the transmission
90) Install the struts
91) Insert and tighten the 3 bolts that hold the strut hat to the strut tower
92) Insert the axle into the hub
93) Install the LCA
94) Insert and tighten the 3 bolts that hold the LCA in place
95) Install the lower ball joint into the knuckle
96) Insert and tighten the bolt that holds the lower ball joint in place
97) Install the brake caliper bracket
98) Install the brake caliper
99) Install and tighten the axle nut (NOTE: you need an impact for this, or have someone hold the brake pedal)
100) Install the wheels and lower the car
101) DONE!
#4 ·
Pics of the Transmission In:
Vids:
0 roll - 100
0914002014.3g2
40 roll - 80 (failed shifts)
0914002011.3g2
  • Like
Reactions: JavierV
#5 ·
Thats a lot of work!
Wondering if its worth it?
#7 ·
Added pics of all the parts today. tomorrow i will be doing the swap. i will do my best to take pictures of the process. i will also be sure to get pics of all my stock parts once they are all off. :)
#10 ·
the trans is in. i am waiting on another axle seal as i demolished one trying to wedge the trans in. that thing barely fits. literally a hair between the differential and the LCA mount. almost need to drop the front sub-frame to get this beast in, tho i did it without.
#12 ·
pics will be up soon. didn't get a chance to take good pics as we were too bush trying to get it to fit. it took us probably 30 mins to just get the transmission to fit in the enginebay. multiple times of jacking it up with the trans jack, trying to move it, lowering it, repositioning, trying again, etc... it weighs like twice that the old one does so it is very difficult to maneuver it.
#15 ·
sadly i couldn't get an exact weight. i don't have anything to weigh it.
i can tho give you an idea of the difference.
with the 5 speed i can lift it with 1 hand. it's that small and light.
for the 6 speed i could barely lift it with both arms. in order to pick that thing up i had to straddle it and lift with my legs, i can barely budge it with my arms.
overall i'd have to say that the 6 speed weighs probably twice as much as the 5 speed.
#16 ·
[quote author=Verto link=topic=172769.msg3662094#msg3662094 date=1274141509]
Good work so far. May start collecting parts later this year.
#19 ·
the seals i replaced because it would be stupid not to replace them. i didn't want to deal with leaks.
for the rear mount bracket, that is needed if your trans didn't come with one. the 5 speed bracket is different.
#21 ·
added procedures. videos of transmissions in action coming soon.
#22 ·
update to OP regarding slave cylinder setup.
it turns out while the slaves are indeed compatible, there are differences. the ms3 slave cylinder has a larger piston diameter. this changes the pedal effort by a lot.
with the MZ3 slave my pedal was uber stiff. with the MS3 slave my pedal is now like stock. (i have the ACT pressure plate which is 48% over stock)
if you use the MZ3 clutch line and the MS3 slave cylinder you will need to transfer the seal on the line from the MZ3 slave to the MS3 slave.
#24 ·
yes. i chose to replace the knuckle for my application. it is easier to swap the knuckle than to press the hubs out. hubs needed to be changed for 04-05
#26 ·
About the speedometer. . .
I have a MZ3 ATX but I also have ABS brakes (with wheel sensors obviously).
So can anyone tell me if if I would get a speedo reading if I swapped?
I am thinking about just dropping an MS3 engine/trans combo in. If I put a new computer thing in I think that should take care of all these potential issue. . . . plus I get a turbo too yay
