41 - 60 of 61 Posts
OK, I was able to finally get the old axle spindle out of the hub. It took a while, but I kept putting penetrating oil on the axle splines and tightening the puller. Eventually, the puller started to get easier to "tighten" and the axle slowly gave way. It took a surprising amount of force to push it out.
Installing the new axle was a breeze compared to the removal of the old one! Just got back from a test drive and everything's A-OK.
Discussion starter · #42 ·
Slider hammer is about the easiest way of getting it out of the transmission.
Last axle I did on a 3 I used one and it only took 3 whacks with the slide hammer before it popped out. Literally only took me 20 minutes from jacking the car up off the ground, replacing the axle, and back to driving it on the last one.
I'm wondering the same thing. I need to do the passenger side seal. I bought the Haynes manual and it really isn't as helpful as it should be. Says to remove the driveaxle first, which directs you to the driveaxle removal procedure, but we don't really separate the shaft from the inner CV joint as it says if all we need to fix is the transaxle seal. At least I hope not.
It would be helpful to have a list of what we need to do to make sure we have enough slack on the passenger axle to get the shaft out.
Does this sound right?
Loosen driveaxle/hub nut
jack up car and remove wheel
remove splash apron around fenderwell
Separate control arm from steering knuckle
Remove brake caliper and hang aside
Take off hub nut
Remove wheel speed sensor
Swing knuckle hub assy out until the driveaxle is free. (support the end)
Undo bolts holding intermediate shaft bearing (and support)
Now we should be able to get the shaft out right? Did I miss anything?
Any easier way to do this?
I used this thread as reference when pulling my transmission out last week. I too damaged the metal dust cover when prying the axle out, and I managed to find a suitable replacement part. I ordered a dust cover from the passenger axle, actually the half shaft on the transmission side. I have pics below, but to foreshadow, I discovered the passenger side dust cover is about 2 mm thicker (longer) than the original drivers side. I thought this would cut into the axle seal, but upon inspecting the axle I discovered that the original dust cover wasn't pressed on all the way. There is actually about 2 mm of space in which you can further press the dust cover into. So I cleaned the area of rust and dust and pressed on the new dust cover. See below.
Part #
Pic of old:
Pick of new:
Installed
Showngo2000
You can get an "inner cv axle puller" attachment for slide hammers... Just google it, anywhere from 20 to 40 bucks or so online.... They are occasionally stocked at some local chain parts stores, but usually have to be ordered in... It slips between the dust cover and transfer case seal and you use the slide hammer in a pulling fashion to pop the axle out. Probably your best bet of removing an axle on the 3 w/o damaging the dust cover...prob good for when you are not replacing the axle but need to remove and replace it to do other work... It should do a clean job, but I'm not 100% certain it will fit our cars. It says fits many ford applications, so i think it might. I would check the dimensions first though before shelling out the money for one.
Hey, thanks so much for this post and the pics. It helped a great deal! Unfortunately, my problem is not the CV axle. I need to replace the clutch. Like you, I was not able to get the lower ball joint to come loose, so your idea to remove the control arm was a great help. I did not have any problem getting the axle out like you though. I used a ball joint removal fork, a block of wood to protect the tranny and a couple of quick hits with a rubber hammer and out it came. Thanks, for the tip on draining the tranny oil first. No mess!
I need to remove the passenger CV axle as well. I am not able to remove the control arm bolt that faces the front of the car as it hits the engine so I can't use your great trick on that side of the vehicle. Any ideas on how I might get around this? I can't seem to get the lower ball joint to behave. I don't think it can be removed without removing the control arm first. The angle it inserts into the hub requires some play for removal and I dont' see how to make that happen.
Thanks,
Dan Howard
I have a serpentine belt tool kit that I bought from Napa awhile back that has found several random uses. This was one such case. What you need is something that resembles a ratcheting open end 19 mm wrench. The serpentine belt tool kit worked perfectly as it comes with a kind of cheater bar that you insert into the end of the wrench.
My kit is very similar to this:
http://www.amazon.com/GearWrench-3680-Ratcheting-Serpentine-Tool/dp/B0002WSFTO/?tag=viglink21499-20
I'm sure an open end wrench is cheaper, but you can use the kit for most any serpentine belt as well.
Oh man, sorry for bumping this, I thought this was current for some reason lol..
I follow this guy to change my CV axles the other day. I was able to pull it step by step for the driver side, but unfortunately I couldn't get around that clip on the passenger side. I have to bring it to a mechanic this week So annoyed that I was able to replace the whole thing, but couldn't get around a tiny clip.
did my wife's Elantra half axles a couple of years ago. Did the passenger side in about 20 minutes without issue. When removing the nut from the top of the lower ball joint on the driver's side the nut went cross threaded (in the middle of the f$#king threads), and just high enough to get my wrench stuck on it. Ended up having to saw off the stud on the ball joint and replace it. Was a PITA because it had to sit on stands for a few days while I waited for parts...... and if it hadn't been for that nut it would have been done as fast as the other side.
I feel your pain.
Am I missing something? I've got a 2005 MT and working on the driver's side. Got the suspension apart including the control arm, all that's left is to get the axle out. Where is this 13mm bolt that holds the axle shaft to the hub?? Am I an idiot? Looking at the outside of the wheel where the rotor is, there's a MASSIVE nut on a threaded shaft, with a little locking notch in it, but that's all I see. What am I missing... this was not in the tutorial
Something that I found out this week actually, when pulling a stubborn axle out of my Subaru trans. There is a rental tool you can get from Autozone called a "FWD Axle puller." It looks like this:
http://www.autozone.com/loan-a-tools/fwd-axle-puller-adapter/oem-fwd-axle-puller-adapter/2061_0_0/
It slides behind the inner CV joint, and you use it in conjunction with the slide hammer (it threads on to the end of the slide hammer) to bang the axle out. It worked when I couldn't get mine out with a pry bar alone.
Another thing; I have an 06 hatchback with the 2.3 and 5 speed, and I could swear that my axles have nuts on the end of the spindle, not a bolt/washer like you say they do.
^ Ive always used a Pickle Fork to do pretty much the same thing. Hasnt ever not worked. Gets the axles out every single time. Ive done literally hundreds this way when i was a tech. Just slide the pickle fork between the axle, and the trans, then hit the base with a hammer. Two taps with typically pop out most axles.
And yes, any 2.3 is going to have a lone 32mm nut. No bolts/washers to be found. Ive actually never seen ANY mazda with that sort of setup.
You can rent either from Autozone for free, after you return them.
I know, Ive used there tool rental programs on a few odd ball parts. But my Pickle fork i own outright cause as i said, back when i was a tech, i was using the thing most every day.
What the heck is the trick to reinstalling the driver's side axle into the transmission on an automatic? I've tried several times and it slips to a point and stops with a little over 1" travel remaining. I've tried rotating the axle while pushing the shaft in hopes it's not that PITA clip preventing it from going into place.
owns 2006 Mazda 3 s
41 - 60 of 61 Posts
