^^^ +1 with manny, the community will be better informed of what u have installed....
Yea, orange is right... That's around about where its meant to spool, comparatively the speed turbo spools much sooner ( low end power) but runs out of steam quickly where as the TP solution uses much bigger turbo which spools later but keeps on going ( mid to top end power )...
Yes a tune may help a bit But i don't think it will bring material gains . If u look at the power band graph for the turbo u will see the turbo is basically kicking in as designed....
So I'd say u have a few possible roads to go down but I still Would not s/c...
1> get a tune and see where this leaves u off, I really don't think this will work for u as I suspect u want boost way down low in the rpm's
2< get a smaller turbo and tune... Gain power down low loose power up hi but I think this is what u want ... I would do a bit of research though into the new turbo before u get it to make sure it's designed to work efficiently in the rpm range u want it to... And that it will bolt into ur setup / minimize mods
3> live with it and adjust ur driving style.... Tbo no one is the same but the attributes that bother u the most are those I am seeking lol
I think u could also have the t/c rebuilt using a differently configured impeller which could allow earlier spool... That said u would again have to research.
Sent from my iPhone using AutoGuide.com Free App
