2010 Mazda 3 Plastic Clip / Connectors - name?
1 reading
230 views 8 replies 5 participants last post by  Grendel65
#1 ·
2010 Mazda 3. 2.0L engine.
Looking to buy replacement "yellow plastic clips that hold the wire harnesses", circled below.
Anyone know what they're called, and where I can buy them?
Thank you.
#2 ·
I'm not sure what they are called, and after checking Mazda's own parts catalog cant find them. However, you could just use two small zip ties! Simply put one loose zip tie around the harness, and then thread another zip-tie through the loose zip-tie and pull it tight around the bolt thread that the other OEM clamp fits onto. Then tighten the zip-tie around the wiring harness. Boom! Secure clamp! Make sure too cut the zip-tie tails though!
#7 ·
This is better than the ones that require a separate screw. I bought a bag of these a few years ago and they come in handy all the time.
#8 ·
Maybe not better just an alternative depending on what is easier to use without modifying something? I use all three and a few more myself . The good thing with using a fastener is you can use existing fasters and simply add the holding device . Whereas the one posted in the last response have more limitation to using them universally.
