Hi all,
I am in the middle of replacing the AC compressor clutch pulley assembly on my 2010 Mazda 3i LF 2.0 5 speed. Original compressor at 164K miles. Works fine. Will have an evacuation and recharge soon.
I have a new complete clutch assembly kit.
Everything is open and stretch belt off.
Do I have to use a 3-jaw puller to get the whole engine pulley-clutch assembly out? I’m thinking so as the new engine pulley has a new radial bearing with its inner race.
The outer facing clutch plate has an 8mm flange nut in the center. No real way to counter hold to remove the nut. Clutch plate spins
Do I want to remove the whole assembly with a puller and then separate stuff?
Or do I want to put the stretch belt back on, turn the engine to “on”, press ac switch to engage the coil-clutch to counter hold things and then break the nut?
Thanks -B
Thanks -B
