1,561 - 1,580 of 1,585 Posts
I'd skip the rear main if it is good. I didn't change it on my '15 10K Fusion that i swapped in my former '04MZ3. It was fine. I used Toyota oil pan, cam housing FIPG to seal the engine. I used it for 17 1/2 years at a Toyota dealership. Bulletproof. Hope the swap goes well and I'm impressed with the purchase price for everything. Sweet. Just sharing my experience.
I got a deal on the parts for sure! I'm lucky that I live in an area where we have lots of yards to choose from. I used car-part.com to find a yard near me that had the engine, IM, and TB that I wanted. As an added bonus I could see pictures of the actual car so I knew that it hadn't been in an front-end collision. When I went to the yard they were pretty excited to hear what I was doing with this swap so they cut me pretty big breaks on the Mazda IM and TB. The engine itself was only $350!
Your thread is definitely one of the ones I'm referring to. I really appreciate all the steps you documented to get one of the newer 2.5's to work!
Not sure what state you are in. I am in California. Does anyone know how this swap would affect me smog legal wise?
That's a good question to ask. If you think about the swap the way most have done it, you are stripping a 2.5L engine down to the long block (only head, block, and internals). You'll be putting back on all the Mazda external parts - valve cover, oil pan, timing cover, IM, TB. It's up to you whether you use a 2.3L or 2.5 IM&TB. You'll be retaining the EGR valve, all your Cats, and pretty much anything else that makes a California car smog legal.
I don't know if an increase in fuel consumption via larger injectors or throttle body and intake manifold will cause you to fail during a smog check. The engine will look virtually identical so it will definitely pass the "eye test."
Lots of folks on this forum have done the swap. At least one (TripWire) is from California.
The OBDII must be compliant regarding the monitor status.
If you are not and you fail you will be required to go to a CALIFORNIA emission inspection center. You may get your VIN code and engine matched for California compliance.
My advise as a licence in the State of California to perform emission testing is to go to a test SERVICE SHOP and ask NOT to be connected to the STATE of California and only want a pre-test. They may or may not charge for the service? It use to be free but anymore I am sure they will charge a minimum fee. This is different than the old advertised by many service shops if you don't pass you don't pay, so DO NOT get them confused. If by chance you do pass the pre-test I would highly recommend to go the full emission test and get your certification right then.
DO NOT supply information about your mods. Let the tech do his job.
Trust me if there is a fault using your engine and you don't pass there will be nothing reasonable you will be able to get to pass it for registering in the state of California.
If you call the DMV or California Air Resource board or BAR they will all give you exact requirements or where to read what the requirements, restrictions or limitation to what is exceptable for changing from the original OEM parts on a California vehicle to pass emissions requirements. I strongly suggest if you first do not take my first recommendation consider the second. DO NOT take your car to any station that is a CA Emission ONLY test center without knowing all the information up front. Once your car is connected to the State Of California for emission testing at that point the engine used if it were a questionable concern will be marked in the states information about your car. At that point any station you go to when they connect your car that information will come up. You don't want that to happen unless you know absolutely that your modding is not an emission concern or violation.
Be careful ANY MEMBERS advise UNLESS THEY KNOW THE CURRENT EMISSION VEHICLE STANDARDS AND REQUIREMENTS FOR EMISSION TESTING IN CALIFORNIA
The phrase "passing the eye test" with respect to the exact regulations...let me tell you!
An example.... during the "EYE" exam if the tech see's a universal bulk cut hose for use for a broken or leaking OEM PCV hose and even if it has emission quality or worded for emission hose requirement but not recognized as an OEM hose in some "eye" "test" will fail the emission test. Even something as mundane and generic like electrical tape none OEM used on something under the hood can fail the test. Really this state has gotten very stick. But then we are lucky we don't technically have mandatory vehicle safety inspections like some other states of countries. At worst if the engine looks like it is not original can lead the "EYE" examination to look more carefully at everything which may include the engine number used or currently in that vehicle being emission tested.
IT IS THE TECHNICIAN ASS and he and the shop could be fined for missing anything not in emission requirements.
Really the old days of slipping a Tech a "c" note to pass are all but gone.
The state sends inspectors for compliance out on the road and they can drive by the shop doing a emission test and look on the internet the car that should be connected. If they feel anything is needing further investigation they can by law enter the shop, check to verify any aspect of the emission test being done.
So I read almost all of this thread, but I’d like to double check.
I have a 2012 Fusion 2.5L engine (got in accident and frame is bent now), it sounds like I can put this engine into a Mazda 6.
Would there be any advantage/disadvantage between choosing a 2004 or 2007 Mazda 6?
This post is a bit poor as im currently posting from my phone. So its a work in progress. Ill. Add step by step purchase list, total cost, and proof in pictures. And a q&a section. My goal is to get a sticky.
I wanted to share with the community that I successfully swapped a 2.5l into my 2004 Mazda 3 2.3l hatch back.
The short story. Got rod knock in my 2.3l motor needed replace. Wanted a 2.5 for the power and no oil leak problem like the 2.3l
Bought a 2011 ford fusion 2.5l motor simply because its way way cheaper than a Mazda brand motor. Its the same long block and that's all u really use. Stripped the ford motor down to the metal. Toss the ford intake, ford wiring harnesses, ford oil pan, ford heater hose block connector thing idk what its called, ford top mount temp sensor, ford intake cam, ford crank pulley, ford timing cover.
Basicallyall you want is the ford long block minus intake cam oil pan timing cover, crank pully, water pully, extra belt tensioners and oil pickup.
Then take pretty much everything off the 2.3 and bolt it to the 2.5 long block. Mazda oil pickup, oil pan, timing cover, intake cam shaft, intake manifold, camshaft position sensor, heater hose connector block thing, and all Mazda wiring.
The ford motor its automatic flywheel so swap that with you're Mazda flywheel and clutch and you need a new pilot bearing to. This would be a great time to get a new clutch if you need it. The clutch kit will come with a pilot bearing.
Here is the guide that i followed its for a Mazda 6 but its pretty much the same for the 3 with some differeces that i will detail below. The ford 2011 ignition and fuel rail are the same as the 04 Mazda. The ford fuel injector is larger to feed the bigger engine and needs to be reused it is compatible with Mazda wiring and ecu. The spark plugs are longer and i used those as well. The spark plug boots look the same so i reused the ford boots as they are newer than my 10 year old Mazda boots.
http://www.happywrenching.com/mazda/6/mazda-6-and-ford-fusion-23l-engine-swap.html
I will be periodically updating this post with more detailed information so check back regularly.
Step 1. Prep:
Purchase list
Ford fusion 2011 2.5L (lkq on ebay) est 600$
Intake manifold gasket (rockauto.com)
rtv silicon gasket maker high temp (walmart)
5qts motor oil (walmart) full synthetic 0w 20
3qts tranny oil (auto parts store API GL-4, SAE 75W-80Capacity 3 USqt
Antifreeze 1 gallon
Clutch kit (optional but you probably should do it if you near 100k)
Pilot bearing (Included in most clutch kits)
Crank pulley bolt and washer. (Got mine from the dealership for like 30$)
Optional: but handy
rust penetrate for all rusted crap
Lock tight high temp
Dielectric grease
Engine degrease
Required/recommend tools:
Torque wrench (required to to it right)
Impact gun (just get one so helpful)
Air wrench(ditto)
Diverse socket adapter set. Long short sockets, extensions, flexing adapters
Good wrench set
Car lifts so so nice otherwise tall jack stands and a crane
Pry bars
Breaker bars
pliers and things
A hose clamp compressor(this thing is awesome)
A coat hanger (thread through the axle holes on tranny otherwise the diff will spin and literately fall apart)
Step 2 get dirty and Pull the motor.
If someone has a good guide let me know and ill post it here otherwise follow the Mazda 6 guide i posted above its pretty good and 90% the same as our car.
Tips manual says to drop it out the bottom. Without a car lift and or a motor jack this sucks. Pull it from the top instead just takes some more wiggling.
CAUTION: when you remove both axles make sure to put the coat hanger through both axle holes. The differential gears are not locked it and they will spin and fall out of alignment. To fix this Right its a a total tear down of the transmission just to put the gears back in place. Happened to me it sucked bad but its not that hard.
Pictures:
THE PROOF Here is the shot of the back of the engine block stating its displacement is 2.5L
This is my car 04 2.5l Mazda 3S
This is the heater block thing. Its different on the ford and has the wrong hose connections. Its 4 bolts to take off fairly easy to do. All the hose connections are under it so i've highlighted the block in a green box.
these are the pullys. I had to remove the mazda crank pully and put it on the ford. Also i had to remove the water pump pully (Center Pully 3 bolts) from the mazda and put it on the ford water pump. Just the water pump pulley was swapped the ford water pump stays in the car.
This is what a pilot bearing looks like. its in the center of the fly wheel
This is the camshaft timing cog. NOTE: ONLY 04-05 HAVE TO SWAP CAM SHAFTS. 06+ its the same as the fords so don't touch the cam and Rock on.
This is the diagram that states that the 06+ are the same as the fords. It only goes to the 2009 but i can confirm that the 2011 ford fusion motor has the same timing cog as the 06-09s.
Part 3 Engine Tear down:
Mazda Eninge
These are all of the parts you will remove from the mazda engine and Transfer to the Ford engine block. BE ORGANIZED there will end up being lots and lots of bolts for everything. Seriously like 100+ bolts Keep it all organized it will make installation much faster. Half my time was looking for the dang bolt in the coffe can of a bazillion similar looking bolts. Good news is if you drop a few don't worry you have lots of duplicates from the ford motor parts you took off.
Head cover (optional: ford one has a big temp sensor hole i didn't like)
Main wiring harness
Ignition Wiring harness
Water block thing
Cam shaft position sensor
Intake camshaft (ONLY FOR 04-05)
Intake Manifold WITH throttle body attached
Timing chain cover
Crank position sensor
Crank Pully (CAUTION:Follow instructions installing this on the ford)
Water pump Pulley ( Only the pully you'll use the ford water pump )
Mazda belt tensioner
Alternator ( My ford didn't come with one )
Starter ( again didn't come with one on it)
Oil filter bracket thing ( for the oil pressure sensor and so jiffy lube doesn't get confused on what oil filter to use )
Oil Pan
Oil pickup ( Black plastic tube thing you'll find in the oil pan)
Oil Dipstick
Ford fusion 2011 motor
Now that you've spent about 4-8 hours taking all of those parts CAREFULLY off the Mazda motor DO IT AGAIN to the ford motor. But all of the ford parts can go into the trash or sold on eBay:
The ford motor has a temperature sensor at the top of the head in between the spark plugs. This is COMPLETELY unnecessary. Just remove it and toss it. Its a solid metal bolt hole so you don't need to plug it or anything like that.
This is what you should have left of a ford motor
Head
Block
Exhaust cam
2006 + cars can keep the intake cam
Timing chain
Water pump NO pulley
Spark Plugs (their longer and a little different)
Fuel injectors ( larger and needed to feed the bigger motor)
Fuel Rail
Spark plug boots (their the same as Mazda but their newer than your Mazda ones so keep em on)
Hope i didn't forget anything
Part 4 The install
Your over the hump all of the dissasembly is done Now that the ford block is stripped an prepared you can begin installing of the Mazda parts you carefully removed.
04-05 start with the camshaft. You will need the timing tools the guide listed. Follow the detailed instructions there. But i will help with an abridged version. Get the timing tools REQUIRED to do it right. Rotate cams to Top dead center. That mean the first 2 lifters (the oval loabe things) are almost pointing toward each other. The front of the cam shaft is the side with the timing chain. On the back of the camshafts is a slot. When at TDC you will be able to slide the timing plat into it. This will keep the cams aligned while you install the chain. When you install the crank pully later you will use this plate again. With the long peg insert it into the side of the block at the specified hole in the guide. Rotate the block CLOCK WISE until i stops against the peg. This is Top dead Center for the crank shaft. Secure the crank somehow so it doesn't rotate even slightly as it can still spin backwards. Now that the crank is secure at TDC and so are the cams Hook up the timing chain and make sure its all bolted down. Cam brackets bolt down to ONLY 16lbs. Thats very light torque these bolts are not grade 8 and you can break them really easily.!!!!!!!!!! DO NOT RELY ON TIMING TOOLS TO HOLD IN PLACE WHILE TORQING DOWN PULLY BOLTS YOU"LL BREAK CAMSHAFTS AND THE TOOLS AND YOU WILL BE PISSED!!!!!
Install the Oil pickup no gasket needed
Install the Oil pan with RTV Gasket maker High temp. BE GENEROUS AND COVER IT REALLY WELL. The last thing you want to do is miss a spot and have an oil leak still.
Install the timing cover. Same rule as the oil pan. LOTS OF RTV. There are also several bolt holes you in the middle of the pan you need to seal with RTV as well.
RTV take 24 hours to properly cure so don't put any fluids in your motor until its set up properly.
Install the crank pully
THIS IS CRITICAL: This is where you can ruin everything. (beside the cam swap if you had to do it.) Bust out the timing tools I KNOW YOU BOUGHT. The flat plate goes into the back of the cam shafts to hold TDC the long screw goes in a special bolt hole on the back of the block. It reaches all the way to the crank shaft. Spin the crank shaft CLOCKWISE will it hits that screw. This is TOP DEAD CENTER. Put the plate in the cams to keep them from wiggling at all. Now Slide on the Crank Pulley. Get out the new Crank pully bolt and washer. DON"T USE THE OLD ONE. This bolt is special its designed to crush and compress and hold the pulley by frcition and pressure. The old bolt won't compress right and can fail during operation. Rotate the pully untill the little bolt hole is at 6 oclock. Take the little bolt and slide it in there is a hole in the block it will line up with and screw it in by hand.
CAUTION: DANGER CAUTION: BRACE THE CRANK SHAFT. What ever you do do not torque down this bolt rellying on the timing tools to hold it still. You'll snap all the tools AND THE CAMSHAFTS WILL BREAK. They are not made to take the extreme torque your about to apply. Lock the flywheel somehow. You might be able to rent a flywheel lock from autozone or you'll have to make one. Or prace the crank pully with stuff. That little bolt in the crank pully will snap or In some cases i've read crack the block.
Ok having said that and everything is all timed up your ready to torque the Crank pully. First torque it down to 78ft lbs. The with a big ass wrench continue turning it an ADDITIONAL 90 degrees. Thats 1/4 a turn Do this slowly. Like push hard then wait 5 minutes. This is to let you rest as this is frigging hard and to give the bolt time to crush and cool down. I'm 270lbs 6'3 and am considered to be a strong man and i found this very difficult to do alone with just a 1/2 inch torque wrench. So grab a buddy and a big cheater bar to get it done. This end up being like 200lbs of torqe.
Good job
Now install the head cover
Great the crank pully and camshaft are the only sensitive and precision steps here. Now just bolt the rest of the parts back on the same way they came off the Mazda. Including the transmission. Make sure the tranny has the little push ring on the rod as it can fall out if its bumped. Grease up the input shaft and that push ring to prevent rust and provide smooth operation. After doing that my clutch is so much smother and easier to depress. It almost feels like its not hooked up.
Now put the motor back into the car. Everything will hoook right up as you have all mazda parts still.
Some problems i ran into
The hose on the back of the intake manifold had a different connector than the Ford. But it was easy to pull it out and put the Mazda hose connection in the block.
Striped alot of bolts becuse im impatient and didn't have rust penetrating oil.
Stripped bolts and broke bolts because i over torqued a lot of rusted crap or very small bolts like the ones on the oil cover and oil pan.
Couldn't remember how the wiring harness went on. That was a long jigsaw puzzle. I suggest taking Detailed pictures before you pull the motor OR as you disassemble all the little wiring brackets and routing paths.
First time starting procedure.
Fill the MANUAL tranny up to 3 qrts as most of the oil probably poored out the axle holes. (How much do the automatics take?) The fill bolt is 24mm and is under the frontside of the tranny and about 1/3 of the way up.
Fill the motor with oil. Since you used the Mazda oil pan your oil capacity is the same. about 4.7 qrts. Fill slowly and check the dipstick regularly so that you don't over fill it.
Now that everything is hooked up and bolted down tight disconnect the spark plugs.
Turn the engine for 15 seconds several times waiting before each crank to cool the starter
This process is to prim the engine with OIL WATER and FUEL.
Now that its had plenty of cranking hook up the spark plugs.
If you did it all right like me it will fire right up.
it will idle rough and run rough for about 50-100 miles as the ECU will be slowly adapting the fuel trims to an optimum value.
If you get any CELS check them out right away to see if they are anything important.
I got a Intake cam timing CEL for about the first 50 miles or so.
I had Major intake leaks as i didn't change the gaskets. I applied RTV on the top of the Gasket and that solved the problem. Its super ugly but i didn't have to take off the manifold as all the leaks were on the top. Picture coming later.
Thats about it. If there is any addition information i left out Please Please Let me know and I will update this with credit to you. Or if i need to rewrite anything becuse i suck at spelling I'll fix that too.
If anybody attempts this Your welcome to ask me question I'll provide all the information i can to help you out.
What did you do about the vvt in the newer motor? Did you just leave it unplugged?
I completed the swap a few days ago and everything worked well. I've put probably close to 800 kms on already. Only problem right now is the idling. It's super rough when it does idle, and the clutch is my enemy. Switching gears is fine, but for any use of the clutch for a longer time than that makes my engine want to shut off. Any ideas? I heard from everyone that it doesn't need a tune or ECU reprogram but I feel like it does.
May have a vacuum leak which wouldn't do much off idle, but could cause idle issues. What intake setup did you use?
My situation is that I just found out my block has holes in it from my 2007 Mazdaspeed 3 2.3l turbo and I want to switch to a 2.5l as I have a friend that has a Mazda 3 2.5l head and block and wondering if it is easier to swap the head and block of 2.5l but will 2.3 parts fit on 2.5l like (Intake Manifold, Exhaust Manifold, Accessory parts, etc.) just hoping to keep the 2.5l and swap everything else from 2.3 to 2.5 or is it easier to swap 2.3l head to 2.5l block.
I just did this swap on my 2006 mazda 3 It was a really easy swap. My only problem is the vaccumn leak at the intake manifold. I just read on here that the holes ore bigger in the fusion head so I will have to make an adapter plate for that. I have worked more trying to fix the leak than on the entire swap. I didn't know what the problem was. I'll try making a plate out of gasket material and see it that works.The temp sensor in the fusion head can be left out then the mazda valve cover will work on the fusion. don't be intimidated it isn't hard.
it's probably a vaccumn leak at the intake manifold.
Do you have a photo that shows what you are referring to?
Are you talking about the 2.5L head having larger intake ports?
I have been running this swap for a while, but am using the Fusion accessory drive layout, Fusion Oil Pan, modified fusion damper, 2006 Mazda 3 intake manifold and the 2010 Mazda 3 throttle body. Curious about the temp sensor as well, as I didn't have any issues with the 2006 cam cover. That's right, I see on the page below that I cut a hole for the sensor.
One place I did find a vacuum leak was the actuators on the intake manifold. The actuators themselves are apparently not available except with the manifold, so I ignored the small leak.
I updated the information about the alternator on my page, in case anyone follows the swap where the Fusion/Later Mazda accessory drive is used.
I'll get to updating the the A/C info eventually, but I used the 2007 Mazdaspeed 3 components, which mount in the locations used on the 2006-2007 Mazda 6/later Mazda 3/2010+ Ford Fusion vehicles.
