5,201 - 5,220 of 6,625 Posts
[quote author=goob_os101 link=topic=124746.msg3972139#msg3972139 date=1300913960]
Car: 08 Mazdaspeed3
Wheels: XXR 527 17x8.25 +35 Offset
Tires: 235/45/17 or 235/40/17?
Suspension: Stock, but looking at Eibach pro Kit[/quote]
Finally some people got these wheels in. Too bad you can only get Chromium black or flat black in 17x8.25. Silver would have looked great on my Sunlight Silver MS3. I am really afraid that the +35 won't fit in the back
The 9.5" range of wheels has not been very documented yet has it? How about a 19x9.5 35 with 215/35/19 tires up front and 19x9.5 25 with 215/35/19 in the rear? The wheels I want come in 25, 35, and 45 offsets in the 9.5" wide.
I am currently running 19x8.5 37 (w/5mm spacer) 215/35/19 in front and 19x8.5 27 (w/ 15mm spacer) 225/35/19 in the rear with lots of camber. Fenders are rolled and pulled front and back and the bumpers are trimmed down at the corners.
Compared to my current wheel/tire setup:
Front: http://www.willtheyfit.com/index.php?width=215&aspect=35&diameter=19&wheelwidth=8.5&offset=37&width2=215&aspect2=35&diameter2=19&wheelwidth2=9.5&offset2=35&Submit=Submit
Rear: http://www.willtheyfit.com/index.php?width=225&aspect=35&diameter=19&wheelwidth=8.5&offset=27&width2=215&aspect2=35&diameter2=19&wheelwidth2=9.5&offset2=25&Submit=Submit
Depending on what coilovers you have, a 9.5 +35 might hit on the inside, so you might need a spacer. I would try to test fit, the +25 might be a better option up front, with as much camber as possible. And the +35 in the rear (that way you won't need as extreme of camber in the rear to look decent since they're so freaking wide).
Thanks guys. I was thinking about running the +35 front and rear. I have H&R coilovers installed and I didn't have any problems with the 8.5 +42s up front. The 9.5 +35 would sit about 6mm closer to the strut than those did, right?
I have 5mm spacers up front now so I could space them if needed. I don't have camber plates up front so the front calculations are more important than the rears. I really just want an even amount of wheel poke front and rear and I would prefer to run some camber in the back since it kind of fits the look and the whole setup is function > form anyway.
hey guys i was wondering will this work. which set will be close to what i want. :)
17x8 offset is 48. hub is 73 will hub rings be needed?
i want to get that beefy tire look. thinking about
235/45/17 or 245/40/17 ? i am lowered on bc coils. rear is maxed out. with 1 finger gap left and front still have more room to go lower but also with a 1 finger gap i am on 215/40/18 18x8 45 now. if i were to get 245/40/17 i might have more wheel gap even if i maxed out due to having 17's
so would 235/45/17 be the better choices? :) :)
[quote author=kalelanalang link=topic=124746.msg4022038#msg4022038 date=1305251201]
buying my friend's rx8 rims.
18x8
225/45/18 tires
i have a 2010 mazda 3 sport gs
04-09 prokit (larger drop than the 2010 prokit)
will this fit or do i need to get 225/40/18 tires??
thx in advance
Did you check the spring rates between the 1st and 2nd gen prokits? Because if i recall correctly the 2nd gen is a bit heavier
[quote author=a1rh3adSz link=topic=124746.msg4022278#msg4022278 date=1305268036]
[/quote] anyone? if so should i go with 225/45/17 in the front and 235/45/17 in the rear?
just got a set of free 17x7.5s...im really wanting to roll with the juicy setup so what is the fattest tires i can throw on them without rubbing also...im thinking 235/45 or possibly even 245s?
Re: The "Will This Fit??" Thread
[quote author=cali_axela link=topic=124746.msg2691137#msg2691137 date=1223948978]
[quote author=Tripleskate link=topic=124746.msg2691073#msg2691073 date=1223947116]
17x7.5 with a +45 offset? Would I rub under any circumstance? I lie to corner pretty fast.
That will be fine, if you stick with 225/45/17 tires.
Question answered, should've read some more, haha sorry.
Delete thread??
[quote author=forsaken7 link=topic=124746.msg4026094#msg4026094 date=1305668606]
I have a stock height on my mazda and I was wondering if 18x7.5 with 225/40/18 tires would fit? Offset is 42 or 43...i dont want to rub or roll my fenders
To be sure you won't have any rubbing with 225's you want the offset to be between +45 to +50. A few mm lower like that, you run a very slight chance of rubbing a small amount over big bumps etc. But you'll be fine, as long as you can live with that. Otherwise, either get the rears rolled a minor amount or go with a slightly higher offset.
