it's pretty simple. VaBoom's instructions are abolutely clear as crystal for this.
Here's a quick breakdown...
1. 2 screws will be removed, after you pop open the covers. (door handle, and center door handle)
(I used a lobster fork for this. lol. worked like a charm, or you can just use a small flat-head screwdriver to pop them open.)
2. You'll need a philips-head to remove the 2 screws.
3. The door handle plastic enclosure will be removed, but you have to unplug the connector, which is done by pressing on the tab buttom with a screwdriver or even key.
4. I used gloves for the door panel removal part. VaBoom demonstrates where to start, which the bottom corner of the door. gloves worked well, as i got my hands in there, and just pulled the door off clip by clip around the panel. I think 6-8 clips total all-around for each panel.
5. The door panel is still connected to the power windows system. Having someone there to just even hold the panel helps, while you can push the tab button for the connector and release it. The driver's side door is the only one that has 2 connectors to release. all the others have 1, if i remember correctly.
That's pretty much it in a nutshell. Vaboom's guide is superior of course, because he'll show you the pics while doing this. I know now after having done it a couple of times. I feel like MacGyver being able to do it so quickly now. Mind you, I had no idea about any of this before.
