CEL (P2177) System too lean off idle bank 1
66K views 20 replies 12 participants last post by  2008mazda32.0l
[quote author=951mz3 link=topic=77107.msg1399551#msg1399551 date=1178770435]
I got the 3" maf housing from pepboys. I attached the maf housing to the stock rubber air duct and put an open filter on the other end of the maf housing. Air filter is really close to the maf sensor, I would say about 5-8inches from the maf sensor. Could that be the cause? Should I put it back to stock?
There are 2 possible problems:
1) Since the MAF sensor is measuring air velocity, the output (to the ECU) will be wrong if the diameter of the air tube is different than stock.
2) The MAF sensor is sensitive to air turbulence. Having the filter element close to the sensor may cause this problem.
