1 - 15 of 15 Posts
I've had my MS3 for about a month now and I've started noticing a rattling sound when I go over some bumps coming from the windshield area. It's not always easily reproducible because sometimes I'll hit a bump and it'll make the sound and then another bump of similar size may not make the sound. I've read some posts about a dash rattling but I'm not sure if it's the same. Does anyone have any thoughts?
Thanks for the links. That's very helpful. I just ran a search and couldn't find much about another noise I'm hearing. Sometimes when turning, I'll hear a slight metallic ringing / grinding sound. It's like taking a metal plate and sliding it against the ground.
[quote author=lead farmer link=topic=136517.msg2952054#msg2952054 date=1235231023]
dealer installed the felt things under the cowl and the windshield rattle hasn't come back. i was getting used to it but didn't like explaining the noise to passengers.
It will come back. Always does.
Lead, can you actually see the felt things? I took my car in for this to be corrected last week and it sounded no different after i got it back. I couldn't even tell if they did anything.
I turn my stereo up too but sometimes the best music is the sound of your engine!
Got those clips replaced, rattle came back about a month later rofl....
Had the dealership fix mine 2 weeks after I got the car.. hasn't returned since.
TSB from Mazda:
CHATTERING NOISE AT BASE OF WINDSHIELD COWL GRILL
Applicable Models
Model Starting S/N Ending S/N Model Spec
MAZDA3 2007-2008 000000 ZZZZZZ
Related Category/Subcategory/Symptoms
BODY AND ACCESSORY / ON-BOARD TROUBLESHOOTING / UNUSUAL NOISE(EXCL. PINGING,SQUEAKING,OPERATION,RESONANCE)
BODY AND ACCESSORY / EXTERIOR TRIM / EXCESSIVE OPERATION NOISE
BODY AND ACCESSORY / WINDOW GLASSES / UNUSUAL VIBRATION/CHATTER
BODY AND ACCESSORY / TRIMS AND MATS/CARPET / RESONANCE NOISE
BODY AND ACCESSORY / INSTR.PANEL/GLOVEBOX / UNUSUAL NOISE(EXCL. PINGING,SQUEAKING,OPERATION,RESONANCE)
MTOL - 5636 Dealer Repair Information
Symptom and Conditions
Some customers may experience a chattering noise when passing over bumps
and/or driving on a rough roads,that may be confused as a dash rattle
at the base of the windshield.
Condition may be the result of a stick slips noise that occurs between
the cowl grill and the windshield.
Repair Procedure
When you encounter a customer with this concern replace the insulator
pads on the 8 hooks of the cowl grill with improved part as listed.
Part No. L206-50-794 Qty. 8 (4 per side)
1 - 15 of 15 Posts
