[quote author=kingpin748 link=topic=133872.msg2882637#msg2882637 date=1232642788]
[quote author=2008jayspeed3 link=topic=133872.msg2877894#msg2877894 date=1232487820]
If you are experiencing this problem with the stock shifter, then adding a sts will on make the problem worse. Due to the fact that the shifter will be able to pop out more easily w/ less distance to travel.
As chodaboy1980 said, it is the stock counter-weight on the shifter that is the problem. Maybe try removing the stock conter-weight on the shifter, and see if it helps. Or purchasing Cobb's replacement counter-weight, if you do not like the feel of no weight. The reason Cobb released their new counter-weight was the stocker was rubbing on fmic piping and was causing the gears to pop out under hard breaking and acceleration w/ thier sts.
It is worth a try before going to the "stealership" and having to fight w/ everyone!
The SS woulds have nothing to do with it, why would it? They just changes the pivot point on the shifter in the car and have nothing to do with what's going on under the hood.
Check the weight under the hood to see if it's actually hitting something. Otherwise this sounds like a tranny issue that has popped up before so try the dealership.
This has happened to me as well. I took off the shifter weight and it has still happened to me on some occasions but definitely not as often. The problem with bringing it to the dealership is you have to replicate the problem for them. There is a very high chance that is will not be replicated, thus I have not taken it in for this problem yet. I have 31k miles on my car, so if this becomes more of an issue down the road the tranny would be covered under the powertrain warranty, correct?
