1 - 8 of 8 Posts
that's the size i have on my wheels with a lower drop.
[quote author=the415 link=topic=67081.msg1152010#msg1152010 date=1168956098]
was it you who said something was catching you tires and you could peel rubber off your tire?
yeah...the problem has been fixed.
I'm running 1.75" with 18x8 RX-8s and 225/40/18's. The key issue is not so much the tire size, but the offset of your wheels. If you are going with an 8" wide wheel you will likely need 48mm or higher. A 7.5"W rim could work with 45mm+.
Kev
Discussion Starter #8
thnx i had the h&r springs put on and a eibach sway bar with 225 40 r 18 bfgoodrich kdw's and they look hella sick with the all black 18 in motegi
1 - 8 of 8 Posts
