114 people have looked at this and not one of them have done a single performance mod? Is the 3 a car just for the LED washer squirter crowd or what?
Did you completely remove the springs? :lol:vividmaz3 said:this is my 3 if some of you havent seen it
just as any other lowered car would ride. its the same.conor said:how bad is the ride? bouncy?
LOL! Yeah right, cutting your stock springs and a quality performance suspension set up are not even close to being the same. The fact is that cutting your springs is the WRONG way to lower any car. Cutting springs will result in inconsistant spring rates as well as weakening the springs. All quality aftermarket performance springs are designed to lower the car and increase spring rates designed to improve handling performance of the car. You should also use aftermarket struts designed to function with increased springs rates any time higher rate springs are used unless the OEM struts have adjustable valving already.just as any other lowered car would ride. its the same.
Who makes the parts you put on?TX2000 said:well i removed the intake rosonator and the stock muffler with a universal one
