1 - 5 of 5 Posts
After recently getting my tires rotated ive noticed a weird vibrating noise that actually shakes my car a little bit. It only happens in the 55-60 MPH range but any lower or higher it goes away.
All ive tried so far was getting my tires balanced which didnt work, so then I had my tires rerotated to their previous positions and I'm still getting this vibration. Any ideas whats going on here or what I should try next?
How many miles are on the tires? Could be defective? Also make sure if they require to rotate a proper way that they are going the right way. Also if you still cant find anything I would check the tires for uneven tread patterns, this could happen if you dont rotate your tires often, or drive with low tire pressure
Do you have aftermarket wheels? Most aftermarket wheels are not hub centric to our cars and need hub rings to fill up the gap between the hub and the bore of the aftermarket wheel. And when you mount the wheels, just make sure that you tighten the lugs in a star pattern.
At that speed, the motor mounts have usually been the culprit. Not sure if it was an issue on the 04's though.
1 - 5 of 5 Posts
