I am neither a supporter or a hater of Fram, and this is a bit off topic, but this is the reason I will not use anything but the OEM filter anymore. I am a member of a motorcycle forum, and this has happened to a few guys on there, and it ONLY happned with the Fram filters.
This Kawasaki uses a canister filter with a metal cap glued to either end.
The glue came apart on the Fram filter and the paper element has torn.
The design of the Kawasaki filter housing is not unlike the Mazda 2.3L (although the cap is metal)
Here is a TSB by Dodge wich actually states the ONLY filters wich are authorized to be used in a Cummins 5.9 Diesel engine.
Date: May 18, 2001
Models: 1989 -1993 (AD), 1994 - 2001 (BR/BE) Ram Truck
NOTE: THIS BULLETIN INVOLVES 1989 - 2001 MY 2500 AND 3500 RAM TRUCKS EQUIPPED WITH A 5.9L CUMMINS DIESEL ENGINE.
Discussion:
Customer may complain of high oil consumption, grey oil smoke coming out of the exhaust or breather tube, or mechanical knocking. Neoprene compounds used internally in the manufacture of oil filters not recommended by DaimlerChrysler may separate from the filter, lodge in the piston cooling nozzle, and can fail the engine.
NOTE: THIS IS NOT AN ENGINE DEFECT.
(See the table below for a list of filters recommended by DaimlerChrysler for use with the 5.9L Cummins diesel engine.)
NOTE: SECTION 2.7 OF THE TRUCK WARRANTY MANUAL STATES DAIMLERCHRYSLER MOTORS CORPORATION IS NOT RESPONSIBLE FOR FAILURES RESULTING FROM IMPROPER REPAIR OR THE USE OF PARTS WHICH ARE NOT GENUINE DAIMLERCHRYSLER MOTORS CORPORATION / MOPAR OR DAIMLERCHRYSLER MOTORS CORPORATION / MOPAR APPROVED PARTS. DAMAGES CAUSED BY THE USE OF OIL FILTER NOT APPROVED BY DAIMLERCHRYSLER MAY NOT BE COVERED BY THE NEW VEHICLE WARRANTY. DAIMLERCHRYSLER RECOMMENDS THE FOLLOWING OIL FILTERS. DO NOT USE ANY OIL FILTER CONTAINING NEOPRENE. PLEASE SHARE THIS WITH YOUR CUSTOMERS.
RECOMMENDED OIL FILTERS FOR USE WITH CUMMINS 5.9L DIESEL ENGINE:
Part Number Manufacturer
05016547AC Mopar
LF3894 Fleetguard Stratopore
LF3552 Fleetguard Microglass
LF3949 Fleetguard Cellulose
3937695 Cummins Cellulose
FL896 MotorCraft Cellulose
L45335 Purolator Cellulose
PF1070 AC Delco Cellulose
Policy: Information Only
Notes:
The LF3349 Cellulose filter does not appear on this list. It was approved in the past for 12Valve engines, but it has been superseded by the LF3949, which has a stronger metal case for the 24 Valve engines. You can use your existing LF3349's for 12 valve engines without concern about warranty coverage.
Here is a (probably outdated) study conducted on oil filters wich seems to be mostly unbiased and the writer will not comment on what he thinks is the "best" or "worst" filter.
Anyway, you may find it interesting....or boring....who knows.
http://minimopar.knizefamily.net/oilfilterstudy.html
Now let me also say for every 1 person that has had a problem with a fram (or other) filter, there are probably 100 who have used them for YEARS without a problem.
I look at it this way:
I drive a 2.0 so the prices may not apply to your 2.3 or 2.3 Turbo
Mazda's "normal" oil change interval is 7500 miles.
Mazda's "severe" oil change interval is 5000 Miles.
If I drive in "severe" conditions, (and most people do if you go by what "severe" means) Ill change my oil every 5000 miles.
If I drive an average amount...say...25000 miles in a year, I will need 5 oil changes in a year.
So, at 5 oil changes a year using a fram extra guard filter $6.99 a piece it totals $34.95 in a year. (price from AdvanceAutoParts.com)
If I use the OEM filter 5 times a year at $13.50 a piece it totals $67.50 in a year. (price at TonkinPartsOnline.com)
It seems crazy to pay DOUBLE the price for a stupid filter doesnt it!?
If you drive 25000 miles in a year you will save $32.55 this year on oil filters.
You will save $65.10 by the time the 4yr 50000 mile warranty expires.
In my humble opinion, $65.10 is not worth the risk of having a warranty claim denied if the oil filter turns out to be the culprit.
Let me say again, that I really belive the majority of people will use whatever filter they see fit, and NOT have a problem with it, but why take the chance?
OK sorry about the long post, and reviving an old thread, my rant is over.
