1 - 18 of 18 Posts
hi..
i thought this post may be useful to some people struggling to change their D2S bulbs.
I recommend removing the bumper and headlights to replace the bulbs. it would make it much easier both or you and your fingers :p
Removal of bumper guide can be found here:
http://www.mazda3forums.com/index.php?topic=41782.0
to start off with... here's how ur HID headlight should be like:
twist the cover anti-clockwise to open it to gain access to the bulb:
this should open access to the bulb:
Then you should be able to twist the igniter socket with you fingers. turn anti clockwise:
Then the bulb's base becomes exposed:
With your thumb, push the clip forward while moving them to the side:
Once both clips have been pushed out, pull it forward to let the bulb loose:
Then simply pull the bulb out:
And simple install in reverse order with the new bulb. its as easy as that...
oh here's some fun shots with my SLR's Macro capabilities..
:D
Discussion Starter #2
Re: How to replace stock OEM D2S Xenon HID bulbs
please sticky :D
Thanks man...this will come in handy when I upgrade mine.
Perfect timing for this thread as I was just planning on ordering new bulbs for my headlights. I didn't realize the bumper would have to be removed just to change the bulbs. What a PITA.
[quote author=hashboogie link=topic=70688.msg1558060#msg1558060 date=1184464833]
Well, you don't have to remember the bumper or the headlight assembly to replace the bulbs, but it is recommended. I took mine out and put them back in without removing the assembly, but I also had about 15 gashes all over my fingers and hands from trying to shove them down in there. I'm definitely taking it off once I upgrade the bulbs. I hated having sore and cut up hands for a week.
[quote author=SuperTrooper link=topic=70688.msg2905640#msg2905640 date=1233554237]
Do all 2008 Mazda 3's come with Stock HID headlights?
i believe only on the 'S Grand Touring' trims they are equipped with OEM HIDs. :)
hey.. i recently bought the stupid d2s bulb.. how much do u guys think would cost me if i take it the dealer and let them do the job??? im new here.. thankss
Do you need a conversion kit to be able to switch the Stock lighting to the HID lighting
or can you just switch the bulbs and it'll be fine?
HID's need a special ballast because they use very high voltage to ignite the bulb. so yes, you need a kit.
does anyone have any recommendations on an bulb upgrade? I saw that the ones in the walkthrough are Phillips. What are the OEM bulbs?
Thanks, this tutorial was great. :), I just replaced both bulbs on mine, took a little longer than it should have, but they are working at least.
D2R bulbs will work, but you may be getting less light than a D2S.
D2R has a stripe on the bulb to limit the amount of light/glare, because D2R are specifically designed to be used with reflector-type headlights.
All projectors headlights uses d#S
Banned
This thread should be sticky. Thanks for the post, totally a DIY in replacing the bulb in the headlight assembly. Can have this as a future reference.
Awesome write up. I hope mine dont go out till i can afford new lights, they are so foggy, i have to use headlight polish on them daily. i was looking at some new lights that look stock on ebay, but i dont know if the HID housings are the same as halogen housings dut to the fact the HID housing has that twist cap.
1 - 18 of 18 Posts
