1 - 6 of 6 Posts
So I am finally getting around to installing my 5701 and my question is does anyone know if I would need the starter work around to use the turbo timer option of this unit. I mean if I can get a Turbo timer and wire it in the alarm should work the same way right?
If I understand the question correctly. You want to wire in a turbo timer while you have the Viper installed?
If that's the question yes, the alarm will work the same way.
Or are you asking if you would need a remote start interface module to bypass the ign immobilizer if you just want to use the turbo timer function of the Viper.
If that's the question, then no, You don't need the interface module to use the turbo timer function of the Viper. Just you won't be able to remote start.
well I mean its 50$ for the interface and all it will do is auto start my car... and well I don't drive it in the winter so I am not worried about being able to start it remotely. Just as long as I can use the turbo timer is all I care about and well all the other stuff you would use an alarm for.
1 - 6 of 6 Posts
