1 - 1 of 1 Posts
I have this vibration sound coming what sounds like the front, I visually checked the motor mount and it looks fine, change axle, sway bar links and hubs bearing less then a year ago, changed passenger outer tie rod, today along with o2 sensor due to p2177 code (Irrelevant), my passenger shock bushing is ripped a little towards the bottom but don’t see that as being the problem, and the only problem I see is the driver side wheel has a little play when I had it jacked up, all other tires have no play, sounds like a hub bearing but I could be wrong, I do need new tires due to uneven wear in the front, both tires balding from inner tire, back tires perfectly fine, sway bar and sway bar links only thing changed on the back end, I only hear the sound when I drive faster then 15mph and are in second gear (automatic 2.3) went 20mph in reverse but can’t hear the noise only when going forward.
1 - 1 of 1 Posts
