[quote author=azazel1024 link=topic=67412.msg1159734#msg1159734 date=1169318150]
I am pretty sure it is made of ABS plastic, not PVC. Either one of which will not withstand the heat you would need to powder coat (PVC starts melting/sublimating around 260-300F, ABS only a bit higher like 300-340F).
-Matt
thanks matt. we usually cure at around 350 so its unlikely it will hold up. i want to try curing at a lower temp for a longer cycle and see what happens. its just for testing purposes basically. if i can pull it off, watch out baby.
