1 - 7 of 7 Posts
I might soon be getting a used 2005 Mazda3 with factory flip-up navigation. I also want to install the Pioneer Avic f700bt. I'll probably only use the factory system for navigation purposes (Pioneer will be for music/entertainment). Would this work with the wiring and everything?
Thanks for any help!
Well the Pioneer you should be able to use the nav and keep your music on, plus it's a HD system instead of DVD-based maps which is a plus.
As for whether or not the factory nav will play well with the Pioneer running in tandem, that I don't know. If the answer is no there are plenty of people here who would love to pick up the OEM system ;)
It should work unless you are replacing the speaker wires. The factory nav system uses the left front speaker to play its voice commands. It's completely separate from the radio.
Rob
Ok so I WOULD be able to use the flip-up for navigation and the pioneer for music?
And Alec, what kind of headlights do you have in your car? They're wicked.
Yes, I believe you can. If you pull out the headunit, the nav system should still work.
[quote author=DutchX8 link=topic=138094.msg2978901#msg2978901 date=1236308247]
Stock headlights modified with the Apexcone DDE kit :) And thanks!
1 - 7 of 7 Posts
