1 - 20 of 44 Posts
got my race pipe today
its mounted on the kitchen table
i have lift access but have to wait untill friday :(
is it hard to do on jack stands.... im about to do it... like now
[quote author=Mattleegee link=topic=73150.msg1296014#msg1296014 date=1175060805]
so i use the copper things and take out the stock things and its all good?
Did yours come with instructions?
[quote author=Mattleegee link=topic=73150.msg1295987#msg1295987 date=1175059037]
Not at all. It's really easy. Might need a helping hand, but it's possible to do it alone.
Discussion Starter · #10 ·
instructions is included.....and the bolts that rpm sent with doesnt fit turboxs race pipe....the tuner i went to have some extra bolts....so diablo if you are gonna do it urself...make sure u have some extra bolts....also that black ring thats on the stock mid pipe is put on the race pipe....
too noisy for me. I don't want too much ricer sounds coming from my car. If I find an exhaust that's less noisy, then I'll probably get it if it improves anything. Is the MS CBE less loud that this?
I already have the Racepipe installed and I personally sopke wthi RPM to get me the proper bolts. Hopefully they fit. If not, I have some nice stainless bolts in my box already.
My fingers are crossed to get it today.
thanks!
[quote author=TruboPower link=topic=73150.msg1295821#msg1295821 date=1175052216]
picssssssssssssss
Do you have to do any cutting to install the test pipe/ race pipe? I am getting under the car to add the motor mount soon and may as well do both at once if I have no cutting involved.
n/m got the answer...it looks so easy even I could do it!
[quote author=Greykiller2005 link=topic=73150.msg1296399#msg1296399 date=1175092201]
picssssssssssssss
[/quote]yea its very easy, even on jack stands, 8 bolts for the brace and then 4 for the pipe. Bingo bango bongo its done. Listen to your turbo sing.
[quote author=GT1 link=topic=73150.msg1296015#msg1296015 date=1175060895]
Nope
I got peanuts, a pipe, and a baggie of bolts... and 2 copper things
guys seriously i just spent almost an HOUR under the car
im no expert on exhaust systems, but i know how to do stuff....
and WTF?
First how do you get those spring loaded bolts off? (race pipe)
Am i like not going at the right piece or something?
Second how are we supposed to hook up a CBE without welding?
I have literally no idea unless the CBE runs all the way into the race pipe
Please help....... quick
Hey, give me a call. Gonna send you a PM.
Actually, nvm. All the nuts on the cat side of the race pipe are welded on, so you unscrew the SILVER nuts. They take some muscle, but apply the right force and you'll get them off. The wrench will probably fall out of your hand but you get the nut loose. Don't worry about the springs, they're not under any tension at all. Then by the downpipe, when you look up, you'll see 2 more silver screws. undo those ones and you're set. Those bolts are longer though.
ok thx wizno
now im on the gaskets
1 is a circle
and 1 has the bolt pattern
THe circle ones definatly doesnt go up front
but then the bolt pattern one doesnt fit on the front either
ANYONE?
Where did you use the gaskets?
[quote author=Mattleegee link=topic=73150.msg1297931#msg1297931 date=1175131008]
ok thx wizno
1 is a circle
ANYONE?
damn...no instructions on a $150 pipe? :(
are you writing a how-to matt?
1 - 20 of 44 Posts
