Trying to tap HIDs to ignition wire for DRL.. HIDs won't come on!
1568 Views 14 Replies 3 Participants Last post by  aznkid.com
Ok, so I understand that if I take my white wire and tape it into the Ignition wire (Green with silver), my HIDs should come on when the keys are turned. I didn't hard wire, but just touched terminals when the keys are turned and nothing happens except it makes a clicking noise.. How can I fix this?
Here's a video of the situation:
http://www.aznkid.com/misc/hid.mp4 (MP4)
http://www.aznkid.com/misc/hid.3gp (3GP)
1 - 15 of 15 Posts
ensure the relay has a solid ground, does the HID ballast buzz?
-Devin
Yes, the relay has a solid ground.. and no, the HID ballast does not buzz..
I've added a video to the thread at the top to show it.. turn up the volume to hear the clicking
Ok, so I took off my ground, sanded the paint down to bare metal, put the ground back on and tried to wire it to my signal bulb..
when I put the e-brake down with the keys in, the HIDs still flicker and the amber corners still don't come on..
[quote author=aznkid.com link=topic=70990.msg1246503#msg1246503 date=1172949975]
Hmmm sounds like you have the wrong wire tapped then. The HID's sound not flicker at all.
[quote author=devin98 link=topic=70990.msg1246514#msg1246514 date=1172950219]
It's the white signal wire that I'm using.. I've tried both the green/silver ignition and the amber corner wires too..
Then there sounds like an issue somewhere.
Can you confirm all these connections
Red - Battery
Black - Ground
White - Signal (amber corners)
Yellow - HID kit positive
Blue - HID kit positive on other side
-Devin
[quote author=aznkid.com link=topic=70990.msg1246525#msg1246525 date=1172950681]
For some reason I have 4 of those big plugs when really I should only have two.. I haven't seen anyone else's HID setup with extra plugs!
The red wire from teh wire harness that comes from the HID kit should be pluged into the Yellow and Blue wires.
-Devin
It looks like you might have received two sets of wire harnesses by mistake
Ok, so I figured it out..
I took out these useless wires:
and it works.. what a pain in the ass!
Great to hear, it seems I sent you two sets of wire harnesses sorry about that :(
[quote author=aznkid.com link=topic=70990.msg1246664#msg1246664 date=1172959629]
[quote author=devin98 link=topic=70990.msg1246688#msg1246688 date=1172961185]
Geez, Devin, why didn't you send me two sets of HIDs when I bought mine lol, I woudn't mind at all.
don't think I made that mistake for awhile :p
aznkid.com: Pictures now that the install is complete?
[quote author=devil2k link=topic=70990.msg1246706#msg1246706 date=1172961832]
Heh they must be for another HID kit because they're nothing like the harnesses I have.. anyways, I will get some pictures goin sometime.. I have to fix my beam because it seems WAY too low.. I can't see anything at night :p
1 - 15 of 15 Posts
