1 - 6 of 6 Posts
anyone know if a 19 or 20 will fit on it??? what size rubber would i be looking at with the 20 if it will fit..same with 19...anyone done this yet or seen on with dubs?? thank you
Kyle
Hmmm.. you can fit either or. on 19s, 225/35/19, on 20s, 225/35/20.
But there is one catch: gotta roll dem fenders boi!
you can easily figure this stuff out with a calculator.
take the rim size and multiply it times 25.4 (wheels are in Imperial inches, you need to convert to metric)
then, take the first 3 digits (width) of the tire, multiply this by the aspect ratio (second 2 digits) divided by 100 (so, 40 would be .40).
then add the two numbers together, then you will have the overall size of the wheel/tire combo.
for example:
205/55/17 overal diameter is: 414.8 + 102.5 = 517.3MM (or 20.36")
So, now you need to figure out how changing the overall tire size (new tires) will affect this number. Your goal is to get the new tire/wheel diameter size to be as close as possible to the number above.
Another example:
414.8 (17" wheel) + 101.5 (225/45) = 516.3MM
That is the overall diameter of the factory 17" wheels and 225/45/17 tires.
While not a perfect fit, being off by 1 MM is as close as you could hope for.
Hope this helps,
PS: To calculate wheel sizes, just factor in the wheel size into the overall diameter of the tire/wheel combo.
you are correct, I was going from memory.... but, the equations remain the same.
1 - 6 of 6 Posts
