im assuming you're getting 17s
here's how to read a tire size.
stock: 205/50/17 (on a s model w/ 17s.)
205 is the width of the tire in mm.
50 is the aspect ratio that determines the sidewall height. so 50% of the width in mm. in this case it's 102.5mm...pretty tall sidewall
17 is the diamater of the tire for the wheel.
a good size for 17s is 215/45/17. you get a wider tire without sacrificing too much sidewall. that's what i ran on my stock 17s after i changed tires.
you could do a 205/45/17 but that gives you a tiny sidewall which is not what you're looking for.
