41 - 60 of 6618 Posts
Re: The "Will This Fit??" Thread
i'm looking at getting some new wheels,
i'm thinking either 18x8.5 or 18x9.5, which offset would you suggest, the choices are :15, 30, 38, 45. i am also lowered on some eibach sportlines
^^Of those you listed, only 45 will work. You'll have to roll your fenders with that wide a rim and drop too. Lot's of rubbing possibilities if you go with 9.5. Imo, a rim that wide on our cars is silly.
yea, i'll probably end up going with 18x8.5 +45 and my suspension set up will be changing before i get any wheels
[quote author=Six link=topic=124746.msg2697978#msg2697978 date=1224886417]
also, will my 205/50/17w yokos fit on these? I just got those tires a couple months ago so Id really like to keep em
They will fit fine and perform great, it will just look quite a bit stretched. Tire Rack lists the wheel width specs for most Yoko 205/50/17 tires as: 5.5-7.5", 6.5" measured. A 225/45/17 would be the best replacement tire for those wheels when the time comes due.
just ordered 18x8 rota P1's ET48. gonna run stock tires (215/40/18?). would i be good AFTER i drop my vehicle 1.5-2 inches?
[quote author=Jonp link=topic=124746.msg2698094#msg2698094 date=1224891356]
Well, I'm pretty sure the stock MS3 tires are actually 215/45/18... but yes that should be fine even with a drop of 1.5". With a 2" drop you might be pushing it and rub the inner fender liner plastic in rare situations.
cool thanks. What tire size would u recomend for 18x8 ET48? Gotta bald out the stockers 1st tho ;)
[quote author=Jonp link=topic=124746.msg2698102#msg2698102 date=1224891741]
235/40/18 for sure -- might have to roll the rears though
cool thanks for the help
listen.. Rolling your fenders is the KEY
u can prob stick a 9.5 in the rear... ill prob try it next yr...
i have a 18x9 in the rear now w/ a 245/35/18 shoe on it....
dont to the baseball truck.. it doenst work too well.. it will get u by for now...
but rent a fender rolling tool + heat gun -- or borrow yoru buddies.. ( thas what i did)
Does anyone know the hub bore of TSW Trackstar 5? It is 18 x 8 and has a 45mm offset but if you look at discountiredirect.com it never shows in the wheels that fit. I also know that people have put this on their MZ3.
[quote author=:: Gusto :: link=topic=124746.msg2700180#msg2700180 date=1225046230]
lmk if you can get 9.5s to fit , but i'll probably be going 8.5, and as far as i know, no one on here has the wheels i'm looking at =)
Can you do a writeup or explain how to roll the fenders on a mazda3? From what I've heard, if you mess up, you risk cracking the paint on the fender...
With that much drop, Yes, you will rub with the stock tires, 215/45/18. (on the top of plastic splash guard inside the fender well)
With that much drop you will still rub on occasion with 225/40/18. On big "g-outs", and mid corner bumps. Same spot on the top of the inner fender liner.
215/40/18 would have no chance of rubbing.
[quote author=Tripleskate link=topic=124746.msg2700737#msg2700737 date=1225070390]
Plenty of write ups on Google about fender rolling. Paint cracking depends on how well you heat up your fenders with the heat gun... I would choose a warmer day and a heat gun (instead of blow dryer). Take your time when you do it... rushing will just result in paint cracking.
<--- was messing around the other day with the wheels on his Maxima.
They work, but the style doesn't.
9.5's with a +40 offset in the rear. Not (fully) driveable without a fender roll/pull though. The 3 is stock height, as well.
I should have taken a picture.
