21 - 40 of 6620 Posts
Re: The "Will This Fit??" Thread
[quote author=sdemo45 link=topic=124746.msg2657140#msg2657140 date=1222837413]
Baseball bat style mack?? lol.
Nah, I got my fenders rolled by that fender rolling tool. The guy did it in the first place didn't use a heat gun and cracked my paint... he also damaged my fenders. I was a little pissed but that's happen when you get side jobs... :(
I got it rolled again by a friend cause it wasn't rolled all the way through.
Discussion Starter #22
Aww sorry to hear that... but I doubt people are lookin at the paint judging by the wheel/tire selection you have.
I rolled them and flare the fonts a pretty good bit. I used a baseball bat I used a article from super street magazine to do it.
i have a set of gram lights. i have no idea what size of tires i should purchase without having to roll the fenders.
17x7.5
+40mm offset
5-114.3 bolt pattern
17.5 lbs lightweight
is the stock tires the only size i can get to prevent rubbing?
Can you rent fender rolling tools from AutoZone, like you can spring compressors? That would be awesome...
i think you can, i wouldn't recommend it unless you have experience rolling though, you may crack paint unless you do it right
The only real trick is to heat it up with a hairdryer or something and go kinda slow... right?
[quote author=Tripleskate link=topic=124746.msg2691073#msg2691073 date=1223947116]
17x7.5 with a +45 offset? Would I rub under any circumstance? I lie to corner pretty fast.
That will be fine, if you stick with 225/45/17 tires.
[quote author=nightsky link=topic=124746.msg2692122#msg2692122 date=1223975371]
What are the max dimensions you can have on a hatch in 18s without having to roll?
18x8" et50 w/ 225/40/18 comes pretty close but doesn't rub at all. Might be able to get away with a slightly higher or lower offset or 235/40's if you're not lowered a lot. Anything wider though, and you'll most likely need to roll to prevent rubbing a little bit.
