Okay so long story short I find myself suddenly in possession of a camper and I'm trying to decide whether it's a good idea or not.
She is a 2014 Mazda3 iSport hatchback, with a manual transmission and a theoretical towing capacity (from the Mazda website) of 2094 lbs, max tongue weight 165 lbs. He is a 2011 Aliner Expedition, with a base weight of 1850 lbs, and an actual tongue weight of 150, once the propane tanks are off.
I already have a tow bar and hitch on the car, and have recently added a brake controller. We towed it around locally prior to adding the brake controller, and it did fine. By fine I actually mean great. It towed very nicely, including up a couple of VERY steep Pennsylvania hills. I even started it up a hill from a dead stop about midway up the hill, and other than a little initial lugging right at the start, it did perfectly. The trailer dropped the suspension in the back by less than an inch.
I plan to remove and lighten a lot of components inside of the camper. Namely, I'm removing all electric bits and bobs that are intended for campground hookups and replacing them with a small solar panel and DC lights and a fan. I'm removing the fridge, the speakers, and all that weird stuff that no one actually uses when they're camping. I'll likely also remove the stovetop, but that's frankly not a lot of weight. I'm also replacing the counter tops with cheapo 1/2 inch plywood and just sanding and coating it.
The issue is that I don't know how much weight this is going to actually remove from the trailer. As is, 1850 is the max I'm comfortable pulling, so once my hiking gear, food, water, etc is all packed up and in, I'd be over my limit.
I don't want to tear this camper apart just to realize that I only removed 100 lbs, you know? I got it for a really good price, but if towing it is going to be dangerous and/or mess up my baby, then it's not worth it and I should just resell it.
So, input anyone?
So, input anyone?
