1 - 10 of 10 Posts
It seems like most of us 3 owners aren't real excited by the drive-by-wire system that controls the throttle. In the interest of better throttle response, has anyone done or thought about doing a swap to a cable? is this even possible?
done....no
possible...yes but it would require a new ecu since ours controls the throttle unless there is a way to bypass it's function.
in the long run, it would be more of pain than to swap than the benefits you would gain, if any.
[quote author=smiler82 link=topic=67873.msg1169220#msg1169220 date=1169765493]
oddly enough i was watching Speed network last night and came across some show where they were building tuner cars. One team took a civic and changed from drive by wire to throttle cable. New throttle body, bracket modification, and a new ECU were all needed. I assume similar measures would be required for a Mazda 3- unfortunately we dont have any 'older models' with throttle cable equipped throttle bodies.
Australian ECU, throttle cable, pedal assembly. Though i think they only got the 2.0 so dunno if it would work on both engines or not. Also could be wiring harness incompatibilities etc that we don't know about. More trouble than it's worth it seems.
ECU swaps in the Mazda3 are not like other cars that I have done that on before.
The ECU has to be from the same exact car down to all of the features.
Besides the the gain if any from doing this conversion would not be worth the time, effort or money. Atleast in my mind.
You want throttle response open up the complete intake track. It would probally be cheaper to get a larger TB made than do the conversion. Or you could test out other ETB from other cars to see if they will work.
o yea and if you have cruise control then you need that motor that controls the buterfly
it can be fixed by tunning software but I'm not sure if anyone is trying to address it. I know that when the new mustang GTs came out (also throttle by wire) they corrected some of the throttle body functions as well as other tuning to drop a sec off its quater mile time.
[quote author=specialized link=topic=67873.msg1177738#msg1177738 date=1170205375]
I'm pretty sure there will never be any tuning of the stock ECU for the Mazda3.
1 - 10 of 10 Posts
