[quote author=Verto link=topic=133855.msg2879421#msg2879421 date=1232525029]
[quote author=Mazda3Mods link=topic=133855.msg2879404#msg2879404 date=1232522637]
A speed tranny? I thought I have been over this. If you do that you need the tranny, shifter + base, shifter cables, axles, and new knuckles on each side and Im sure some more I am forgetting...have fun with that costing less
PLUS, the gearing on the 5 speed is PERFECT for boost. Even with only 200whp on txmicas turbo 3, I was able to beat a handful of speeds (modded speeds at that
most around 250-260whp).
you don't need knuckles. axles are the same on the hub side, different on the trans side. just an fyi
Interesting, I just new the axles were WAY beefier on the speed than the 3...so I figured both knuckles would need replaced.
OP- are you working with a 2.0 or 2.3
