1 - 5 of 5 Posts
Ok, so i'm having issues with stability at 45mph+ speeds. Steering seems like there is too much play when centered. I've already checked my linkages in my suspention and have found 0 play in all 4 corners. I am in need of new tires probably have about 3000mi +/- left on the tread and am unsure if i should rush out and get new tires because of this issue or if there might be some other underlying cause. I hope it is just the tires giving me this trouble.
Thanks
Tires would cause that. If they are not stable I would highly suggest just going out and getting some new ones. 3,000 miles is not a lot of tire left specially if they are not wearing correctly.
Cool!!!
I think i might as well get the alignment checked while i'm there too. Should i get the mechanic to 0 in all of my settings or try to stay as close to oem alignment as possible?
i don't think you want 0 camber, caster and toe. car might not track or handle properly
imho, stay near or within oem specs. for daily driving.
you can wait for other opinions...and I was going to add, have them inspect your shocks/struts. if you're floating at higher speeds, these may also need replacement.
Oh my god just got my tires on the other day!!!! The car feels sooooooooo much better!!!!! Had them line me up too and now the car is not pulling when i launch well not as bad anyway. I wound up getting the fusion zri ,i think it's zri, it's z something anyway. I like them so far especialy because they ride sooo much better than the pos nankang that came with my rims. Thank you all for pointing me in the right direction.
1 - 5 of 5 Posts
