posted these questions elsewhere but thought they deserved a stand-alone thread.
does anybody have info about the stock ECU map and what the MAF readings are (% of peak Volts) and what the injector duty cycle is under WOT conditions? never owned a direct-injection engine but I assume it works along the same principles as side-feed injectors. meaning the stock injectors are rated for a certain max flow rate (mass/time) - what is that flow rating? and lastly how's the stock MS3 fuel pump compared to the max injector flow rate?
again, coming from a Subaru background, these were very real limits and concerns when it came time to increase the volume of fuel/air burning through the engine. the WRX was especially limited by its small stock injectors and the fuel pump needed to be upgraded from day-one.
perhaps these questions belong on a thread for a ECU mgmt system like the Xede but I thought I'd raise it here. if this has been discussed elsewhere, I'd appreciate a friendly linky.
edit: opps. probably belongs in a different topic area. can a Mod please move this to "General Powertrain" forum?
