1 - 12 of 12 Posts
Hey, I was wondering if any of the expert around can help me with the problem here. I did search around the forumn but most of the post i found isn't really what i need...or maybe i just missed it...well here it is...
I just bought a set of fog light on ebay, try installing them and found out that i already have the stock wire behind the bumper and a green harness under dash. I still try to put the switch that came with the fog light in but somehow it didnt work out...so i went around the forumn and found the part number for the stock switch....but the stock switch isnt just a fog light switch next to the dim, the fog is attach to the headlight at the steering wheel? So i was wondering if anybody know the part number for a switch that i can install next to the dimmer and not the steering wheel switch...
btw: my fog light kit is exactly like this one
http://www.mazda3forums.com/index.php?topic=48756.0
but i also have the stock wiring for both the lights and under dash...and the one from ebay dont fit in stock...
Thanks!
There is not "stock fog light switch" in the dash next to the dimmer. The stock fog light knob (more like a ring actually) is on the stalk with the head knob.
oh...the protege fog switch in dash fits? I read the other post and i am not sure if the wire harness from the stock fits your switch harness. Did you modify your switch to fit the stock harness or does it just fit perfectly? Thanks for the heads up guys~!
[quote author=wytwolf link=topic=69595.msg1213641#msg1213641 date=1171719440]
Anybody know what the OEM i model fog light kit use for a switch? If it is a real dealer-installed kit it would see awkward to replace the turn signal stalk.
i have an i model and i installed the factory fog light kit and it does replace the light stalk on the steering column.. it was really easy to install everything from the kit.. the instructions are very thorough just like my auto dim instructions and i didn't have any problems installing anything and i'm not the handy type.. but the stalk just replaces the old stalk and it looks great. i'd rather have the light stalk on the steering column then have a switch by the dimmer.. i think it just looks better and that switch from ebay isn't the same color as the rest of the interior.. you can just purchase the stalk from the dealer for $60 and it will work with your aftermarket fogs.
1 - 12 of 12 Posts
