1 - 13 of 13 Posts
Just curious but when I start my MS3 the rpms go imedietly to the 2k mark, I only have 468 miles right now and was kinda thinking that was just part of the break in. As soon as I put it in gear and start driving they drop imedietly. So, is this normal??
[quote author=Nymisus link=topic=68035.msg1172493#msg1172493 date=1169961160]
You should let it warm up a bit before driving off. Mine does the same thing and I let it drop to about 1k (which doesn't take that much time)before putting it in gear.
good to know this is a common thing, although it takes at least a minute for it to calm down and when it does it goes slightely under the 1k mark.....
[quote author=Nymisus link=topic=68035.msg1172601#msg1172601 date=1169968542]
Yeah, it seems like forever when you're waiting for it, but in the grand scheme of things, a minute isn't that much time. At least that's what I have to keep telling myself while I wait for mine to warm up, hehe.
Mine seems to vary between 2,000 and 1,500 without any real explanation (e.g. not temperature dependent). I raised that with the dealer when I went for a first service, and he claims it is normal, nothing to worry about, and probably a result of whether the AC, etc., is in "on" position when started. I never change those settings, so this isn't it, but I've stopped being concerned.
it is normal especially on turbo cars. the turbo uses engine oil to keep lubed and the engine idling high for a few sec. helps the oil get there faster, keeps the turbo from running dry for a longer period.
yup. mine does it too.
I give it 30 seconds, then drive slow in 2'nd or 3'd (about 25 mph) for the next one minute atleast.
more importantly, do not RACE the engine on idle and do not hit the gas pedal when starting up. Just turning the key should be enough for a clean start.
The primary reason for the increased cold idle speed is emissions related. The idea is to bring the catalytic converter up to operating temperature (> 250 C) quickly. It has nothing to do with the turbo.
It's the temperature. If you start in a warm afternoon, it usually starts from around 1500, and goes down quickly. I think that's because the oil is more dense when cold.
I always wait until it goes below 1000 and the temperature gauge starts rising.
[quote author=GT1 link=topic=68035.msg1173969#msg1173969 date=1170046287]
he is right...it idles at a higher rpm at first as the temps go lower.
1 - 13 of 13 Posts
