1 - 11 of 11 Posts
My seat on the driver side is very squeaky when I make turns, Does anyone know how to fix this problem? It gets louder and louder.
Typically, it's the seatlbelt anchor. Try a squirt of WD40 or a like product and see if that does the trick.
Okay, I'll try that, have you had that problem before?
Yes, myself and many others. It's been awhile since since been discussed though.
Yeah, give it a try, hopefully that's all it is.
Okay sounds good, thanks much!
yeah I had the same problem...deff is the seat belt janks!
Yah first it was on the passanger side, now it's both, I'm going to lub them up today
My car had the same problem with the drivers seat. I thought that the problem was with the screws that hold the seatbelt anchor (on the right side of the seat).
I removed the seat, removed the bolt that holds the anchor in place, then applied lithium grease. Problem solved.
Fortunately, I had lots of experience removing the driver's and passenger's seats.
[quote author=danielj link=topic=139407.msg3007791#msg3007791 date=1237600280]
Just a heads up to others. Most do not have to remove the seat to solve the squeaking.
Agreed! I removed my seat I because I already had experience removing the seats (installing
a sub and amp), and I wanted to see if I could prevent the squeak from returning by understanding how the whole assembly works.
1 - 11 of 11 Posts
