1 - 5 of 5 Posts
if i get a new sound system, i'd be looking for something with high quality/bass (not necessarily how loud it can be) but not too expensive..
how much should they cost? how much amps should i be looking for? are there any other specs and products i should be looking for as well (i.e. subwoofer size)? and typically how much would labor cost (or is it easy-install stuff?? im assuming its easy?).. im trying looking for total cost under $500, but def. under $1000
also...
what do u think about these?
http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/Amplifiers/GMSeries
http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/Subwoofers/Champion
http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/Speakers
what should i need? are there anything else i should be looking for?
im running a GM-6300F 4 channel and a GM-7300M class d.
atm i only have the 7300m hooked up. it's 800w max, and it's powering a 10" shallow mount sub in a ported box.
planning to get Pioneer TS-D1720C for my fronts and Pioneer TS-D1602R for the rears.
because i don't have any components i can really only comment on the sub setup. cost $200 minus the box and wiring... and it sounds great. hits hard and gives a nice clean sound.
i believe it's a matter of personal choice... so pick what you like. in any event you'll need the basics. an amp, a speaker whether it be a sub or mid, wiring both power and speaker, and maybe a distribution block or two depending on if you run 1 or 2 amps.
whats the difference between 4 channel amps and 2 channel amps?
are the price for speakers per 1 speaker? per a pair of 2?
and lets say i get a 600W amp, and if i get 6 speakers.. would i get 600W speakers each, or 100W speakers each (600W total)?
[quote author=XB link=topic=139610.msg3009463#msg3009463 date=1237702818]
That Depends On The Amp You Get, Usually If You Read Through The Spec Sheet Or Manual, It'll Say How Many Watts Are Given Per Channel @ Whatever Impedance.
speakers are sold in pairs, with the exception of subs which are sold separately.
1 - 5 of 5 Posts
