Couldn't make an account on mazdaspeed forums so thought I'd start here.
My shift linkage cable broke in half. Luckily got stuck in third gear so I could drive home. Is this a part I can unbolt and replace or re-weld or is it more on a new transmission side of things.
2012 mazdaspeed 3
Did you fix this? I only have the G35M-R 5-speed service manual, but I think the mechanism is fundamentally similar. It appears you can use leverage to pop off the shift cable ends, then the remaining shift mechanism unbolts from what you can see in your photos. There looks to be a couple keys that connect it to the shift rod (recommended "replace" items during service). The manual calls your broken assembly (on the G35M-R), "shift lever component":
106180
