My car used to idle at around 30psi steadily once fully warmed up, but after my last oil change has been dropping down as low as 18psi steady and seems to bounce around a lot more too (between 14-20ish). Triple checked oil levels and all connections, it's right at the full mark and everything is tight. Should I be worried or is this a relatively safe / normal idle oil pressure?
What's the lowest oil pressure you guys see at idle once the engine is fully warmed up?
