[quote author=the415 link=topic=69352.msg1203550#msg1203550 date=1171331339]
you dont understand the way an engine works.
here is a dyno chart
see how it peaks at 6500 and starts falling....after that point, you aren't making the most hp. so you have to shift to the next gear and start climbing up the powerband
I disagree somewhat. Yes, power falls off after 6500. Yes, a shift there will put you in the power band. No, it's not always the most optimal point to shift. Gear shifts are not instantaneous. They do rob you a good fraction of a second where you are not on the power. A no-lift shift will reduce this, but is murder on the drivetrain. Assuming we are both driving a 3 with the same setup with a close launch; while you are shifting at 6500, I will be accelerating away for 600 more RPM a fraction of a second longer. By the time I shift, I will be slightly farther ahead and even closer to the maximum torque point. This car doesn't accelerate fast enough for you to make up the lost ground from shifting early.
Another thing, in your list of mods for high RPM power, you didn't mention the cams which is the single biggest factor next to the intake manifold. The cam profile is what dictates volumetric efficiency other factors remaining constant. We already sort of have a short intake runner. That's what the Variable Induction Manifold is supposed to provide a means for.
Also, about the dyno from Bean, I thought these engines were supposed to have at least 90% of maximum torque available from 2500 RPM all the way to the redline. Did those mods affect this, or was Mazda exaggerating a bit?
