1 - 6 of 6 Posts
i have the model 2 and they aren't tpms compatible. good thing i dont have tpms.
Eek!
What makes them incompatable? Is it the size of the hole for the valve stem? I was hoping I could just swap out the sensors to the new wheels, but this is not sounding good so far . . .
btw, how do you like the wheels?
Dmc3
yeah i think it's the size of the hole. guy at discount tire gave me shit about them b/c he thought i had tpms. i had to drag him out to my car and show him.
i love the wheels. they are holding up well. i got them on halloween and im ready for new ones though. i change my wheels like i change my shoes. hahaha.
Discussion Starter #5
I wonder if changing the "grommet" would allow them to fit. Found this elsewhere on the forum. Gettin the itch to cancel my order, but the wheels seem like a deal and they look good. 17" at 16.3 lbs a piece. $425 a set. Crap. Decisions . . .
"Yes, you can swap out the sensors into new wheels. I work for America's Tire Co. aka Discount Tire Co. The inner part of the sensor has a rubber grommet that will not fit most aftermarket wheels and should/needs to be switched to a larger grommet or the valves will leak at the base. Most tire shops carry performance valves that have the larger grommets that can be swapped to the sensors.
I have a 3 5door with 18" Enkei LM1 and I swapped out the sensors and grommets with no problems. When you change tires or change wheels the owners manual tells you how to reset them if the light comes on."
your best bet is to call rev.
1 - 6 of 6 Posts
