So, I saw a quote in a post elsewhere from DynoDynamics which states that 1/2 or more of apparent powertrain loss on a dyno is actually friction loss from the tires, while loss from the actual powertrain components is only 1 or 2% per gearset. If true, it occurs to me that this is the major reason that an AWD car can conceivably dyno significantly lower than a 2WD cars and still accelerate as fast. Look at the dyno on Cobb's site for the MS6. On it's face, it's not even in the same ballpark as the MS3. (I know: different dynos, different days, different locations, the delta is all that matters, etc., etc.; but even allowing for that I think my point holds water.) Yet we know that even with the weight penalty, the MS6's acceleration is neck-and-neck with the MS3's.
Sure part of this is better traction, and not just at the dig, but at higher speeds as well. But the more significant part may be is that dynoing an AWD car takes into account 100% of the friction losses from the tires, while dynoing a 2WD car on a single roller may account for only 1/2 of those friction losses.
This may be another reason (in addition to possible interference from your traction/stability control) to dyno 2WD cars in AWD mode. Now, I'm not sure exactly how it works when a 2WD car is dynoed in AWD mode. On a Mustang, the rollers are linked so that the rear wheels spin at the same speed as the front, but rear wheel friction losses still may not be accounted for somehow. Maybe somebody who knows more about the subject can shed some light on this question.
