A phillip head screwdriver. Turn counter-clockwise.rpc180 said:Is there a way to aim the projectors a little higher up using stuff in my garage? I only want an additional 2-3 degrees. The beam cut off looks awfully short.
It should be right next to the motor assembly by the highbeams. Just look for the only thing that you can stick a cross tip screwdriver into. Park the car with lights facing a wall, turn lights on and turn to screw to adjust.rpc180 said:Where's the adjustment screw located?
I have regular halogens. There are two white plastic caps that are next to the headlight assembly cylinders. Neither look like they can take a screwdriver. Finally, on the very top center of the projector casing there's this U-shape heatshrink that's covering one end, the rest just dangles there. I thought a screw might be inside but I can't adjust it unless I remove the heatshrink (and I don't want to do that until I'm sure).BTW... This is for the Xenons.
