Group buy for Prosport Premium Boost Gauge with programmable Peak Warning light. The gauge is red illuminated with a silver trim which matches the speed interior so well. It is similar to Defi BF Boost gauge in looks but is much more reasonably priced. The group buy would be for a minimum of 20 buyers at a cost of $77 shipped instead of $90. If we get more than 20 we can get a better discount so buy now! It is a slim design as we all need for the defrost vent gauge install. Any install would be easier with a gauge that only has a depth of 1.25" after the bezel rather than 2.5" like most gauges. This GB will last a month top the middle of Feb dependent on interest.
http://prosportgauges.com/prosport_stepper_motor_series_ga.htm
Info on group buy gauge:
Electrical Boost Gauge with Warning & Peak
This ELECTRICAL Boost Gauge will perform a pointer sweep/self check on start-up & shut down!
If your vehicle is supercharged or turbocharged then this gauge is simply a must have. For peak performance you need to know how much boost you are making at maximum RPM's.
Now you can track your peak boost as you modify your ride!
Save your Turbo-Set the warning function to alert you when you over boost!!
(-30~30 PSI includes Mounting Cup, Tubing kit, T-Adaptor, Electric Sender, quick connect pigtail wiring, Visor, Decal and Instructions)
52 mm (2") Stepper Motor Driven 270˚LED Display.
These are fully programmable to allow you to set the warning feature to either beep or change color (or both) once the gauge reaches your pre-set limit.
270˚ dial sweep provides quick one glance accuracy. Track tested and race proven these gauges use precision electric senders to keep hazardous fluids out of the passenger compartment.
All of our Premium Series gauges perform a dramatic opening ceremony with a full pointer sweep each time the vehicle is turned on AND Off.
These are very easy to use, all programming is done from the front push button!
Wire up the first gauge for power and daisy chain the power to each gauge as needed! As only Prosport would do, the Daisy chain power leads come with them! Nothing more to buy.
These Gauges are Super Thin! Perfect for tight mounting options:
Vid:
http://www.youtube.com/watch?v=XuLIrLpZx3A
PM any questions to me or if you want to be on the list PM me with your e-mail.
Once you are the list and the group buy ends you will be contacted by the company for payment Please do not get on the list if you do not have the money in hand to buy.
Vid:
