1 - 5 of 5 Posts
Anyone out there please help
After i installed my H7 HID for my M3GT it's flash like crazy during the daytime
And i heard someone said just hook up to the Fuse box under the hood to make my HID on all the time. Because i am from Canada. I do not want to disable DRL, that is the law. So which wire in the fuse box need to tap it with the wire of the relay harness? Or any other way to make my HID on all the time. Thanksssssssss
you should see a topic right here about that.... but using the foglights... its about trying to make them independant.... so there u can see the pic of the fuse box and then from that you can know how to make them independant (headlights) and turn it on whenever you start the car.... be fast!!!! because that flashing damage your ballast and you entire HID!!! so be fast i u dont want you hid burned
So i have to do exact the same for my headlights? Do i need to pass the wire throught from under the steering wheel?
1 - 5 of 5 Posts
