Hey guys,
Got the following codes on my Mazda3 2005:
p0442 - freeze frame
p0442 pending
p0455 pending
From what I have read this is the purge solenoid valve. Should I replace it DIY? I saw a walk through and it looks easy enough. Also, I have a Mazdaspeed CAI, do you recommend I clean the MAF? Could that be part of the problem too?
Any advice or reassurance I am on the right path is appreciated
thx.
**update: Aug18, 2012**
Bought the solenoid purge valve at the stealership for a $120 gouge. Replaced it myself, took all of 15 minutes. Followed the walk through on this site, its super easy (no pics required to follow).
Step 1: Disconnect negative terminal of battery:
Step 2: Disconnect the wire clip from the solenoid valve:
Step 3: Disconnect this fitting near the firewall with the quick-release connector:
Step 4: Disconnect this fitting from the front of the engine:
Step 5: Slide the solenoid valve towards the front of the car to release it from the rubber fitting that holds it in place:
Step 6: Loosen the hose clamp connecting the line from the firewall to the solenoid valve, and remove old valve (which remains connected to the front line).
Step 7: Connect quick-release clamp of new front line to the front of engine (simply snaps on).
Step 8: Reconnect the rear line to the new solenoid valve and tighten hose clamp. Make sure the raised line of plastic on the valve is lined up with the marked line on the rear hose, and slide the solenoid valve back into the rubber fitting:
9: Snap rear line back onto the fitting coming from the firewall.
Step 10: Reconnect wire clip and battery cable:
Step 11: Done!
Step 12: Don't forget to remove this plug from the new front line before trying to connect it :
Total outlay: $210, but.... For $90 I bought a OBD2 scanner (in a bundle that included a battery tester and live circuit tester) and the part was $120. I get to keep the hardware and I did not have to pay the stealership their rate of $119 just to look at my car. Not sure what the stealership total would have come to but it is certainly more than my DIY with hardware purchase. Hopefully this solves the problem, so far so good, if my gas cap seal is bad that would cost $55 to replace the cap (anouther stealership gouge). May look online for a better deal if needed...
Hope this helps someone else who may have this problem
