[quote author=Darkfrosty7 link=topic=137167.msg2956467#msg2956467 date=1235429381]
yea i really need help... i think my rotors are stuck i tried everything to get them off. is there anyone that can give me a procedure? or how to get them unstuck or anyone that had a simular problem and can tell me how they fixed it?
Fronts or rears ???
I had to bust mine off using a Mallet from behind.
My rears were a pain, they are rusted in place, you might have to give it a few good whacks from behind and tap the front all around, mine took me 10 minutes each.
Try using a rubber Mallet first, if that does not work, use a lightweight hammer or Steel Mallet, just dont go crazy, turn the rotor as you hit it, firm but not hard.
I suggest you grind off the rist once rotor is off, use a wire wheel or a drill attachment, I also grinded off the rust on the insides of my wheels, this makes for a smooth alignment upon install of new rotors.
